ganz924S
Posted: Sun Nov 01, 2015 3:35 pm Post subject: New Owner Electrical Gremlins |
Hi, new member and owner. My 1988 924S is in pretty good shape and running. I plan to do belts and water pump as soon as I sort out the electrical. Here are the issues I am dealing with:
-Headlights will pop up turn, but won't pop back down. I have rebuilt the motor swapped out the motor relay and cleaned up the switch and they are still not working.
-Rear Driving lights don't come on.
-Both windows won't roll down.
-Interior dash lights don't come on.
I have cleaned the one ground under dash I found behind the main fuse box.
Does anyone have any ideas or a good wiring diagram?
Thanks!
[img] [/img] _________________ 1988 Porsche 924S Guards Red |
Posted: Sun Nov 01, 2015 5:06 pm Post subject: |
Welcome! She looks good!
Clarks-garage.com has some good write-ups and Pelican Parts has some wiring diagrams for the 944.
Hope that helps! _________________ Stefan
ganz924S
Posted: Tue Nov 03, 2015 12:44 pm Post subject: |
Thanks! I found the wiring diagram on Pelican Parts, now just need to figure them out. _________________ 1988 Porsche 924S Guards Red |
michaelodonnell123
Posted: Wed Nov 04, 2015 5:59 am Post subject: |
Welcome aboard. We both have the same car a 924S [good choice!]
Sometimes the issue with the windows are the switches in the door panel. Using a flat blade screw driver you can gently pry [prise] them out. The tabs are on the side of each switch. Once you get it stared you can use your fingers to pull them out. Then disconnect the harness from the switch and put them on the kitchen table where you can remove the rocker button on the switch and clean the contacts inside. I used a dremel tool with a small wire brush. Make sure you put the metal rocker contacts back in exactly as you found them otherwise things wont work right. [hopefully the previous owner didn't put them back wrong as well]
Note* the drivers side passenger window switch is linked to the passenger side windows switch if one is not working, neither will the other! _________________ MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500 |
ganz924S
Posted: Wed Nov 04, 2015 3:48 pm Post subject: |
Thanks, I just got done cleaning up the window switches and had no luck. What I am thinking is that the previous owner cut a ground when he was trying to wire in an aftermarket stereo. Going to try and go through the wiring diagram this coming weekend and see if I can sort it out, hopefully I don't have to pull the dash off... _________________ 1988 Porsche 924S Guards Red |
Posted: Wed Nov 04, 2015 11:45 pm Post subject: |
You can apply power directly to the window motors to verify if they actually work before going to far into the wiring.
The motors do fail/seize up from time to time.
Good luck! _________________ Stefan
