Fuel lines question
michaelodonnell123
PostPosted: Mon Oct 12, 2015 12:04 am    Post subject: Fuel lines question Reply with quote
Hey everybody -
Just wondering if these two fuel lines can be replaced without dropping the gas tank? I filled up my tank today and these lines feel moist and wreak of gasoline. Not fun to drive in a car with those raw gas fumes.
MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500
PostPosted: Tue Oct 13, 2015 11:37 am    Post subject: Reply with quote
Wow, since you unearthed this part, which is not for the faint of heart, (the white plastic cover can be brittle) you might as well drop the tank. Looking at PET, you have two vents, one by the filler and the other on the other end.
http://www.autoatlanta.com/porsche-parts/924S-86-88/porsche_924_parts.php
PostPosted: Tue Oct 13, 2015 11:48 am    Post subject: Reply with quote
Answer is no, and if you are committed to the car, Dave is right about dropping the tank and restoring everything in the area.
michaelodonnell123
PostPosted: Tue Oct 13, 2015 12:19 pm    Post subject: Reply with quote
which part is the white plastic cover. The cover that I removed was a metal cover.
MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500
jason c
PostPosted: Tue Oct 13, 2015 1:00 pm    Post subject: Reply with quote
The metal cover superceeded the plastic cover for fire resistance.
michaelodonnell123
PostPosted: Tue Oct 13, 2015 1:06 pm    Post subject: Reply with quote
The tank is coming down tomorrow and yes I will fix/replace anything that needs it while I am there.
This is a job for superman.
MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500
jason c
PostPosted: Tue Oct 13, 2015 1:24 pm    Post subject: Reply with quote
Not really. Take the rubber portion of the filler neck off at the tank & it is much easier. If you leave it connected to the tank, you'll fight it because it hangs up on the way down.
You'll have to remove or at least lower the trans to get the tank out. That's the hardest part of the job.
michaelodonnell123
PostPosted: Sat Oct 17, 2015 2:06 pm    Post subject: Reply with quote
Just finished up the job. Took down the tranny and while I was there I fixed an exhaust leak too. I replaced the gas lines and buttoned everything back up. No more fuel smell and a much smoother idle and responsivness as well by fixing the exhaust leak.
MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500
