87' 924S sitting too long
Jim Adkins
PostPosted: Thu Oct 15, 2015 2:55 am    Post subject: 87' 924S sitting too long Reply with quote
My little Lady has sit for 3 yrs while I've recouped from medical issues. I posted about this earlier but cannot find the posts so am re-posting. I've changed the spark plugs,(after spraying some Marvel Mystery Oil into the cylinders) new plug/coil wires, added Stabil to gas tank along with 5 gal of new super gas. Am wanting to change the cooling fan relay as I was having an overheating problem (the fan kicked in but temp was too high). I am having trouble getting the old relay out of the socket, whats the secret?? In my owner's manual it's shown as I (roman numeral) I also noticed quite a difference in the height of the old compared to the new. New relay is a Wherle #20-240-073. Any help this old guy would appreciate much.
Thanks
Jim
87' 924S, Red
Jim Adkins
PostPosted: Fri Oct 23, 2015 12:57 am    Post subject: Reply with quote
Need a bump on this. Anyone able to tell me how to remove this Fan Cooling Relay? Having trouble with my big, klutzy fingers gripping it.
Thanks…..Jim
87' 924S, Red
PostPosted: Fri Oct 23, 2015 2:14 am    Post subject: Reply with quote
Are you talking about the one screwed into the radiator? Here's one at Pelican, have two temp ranges.
http://www.pelicanparts.com/catalog/SuperCat/944M/POR_944M_ELSWCH_pg8.htm#item23
jason c
PostPosted: Fri Oct 23, 2015 10:06 am    Post subject: Reply with quote
Thanks…..Jim
Just wiggle it side to side while pulling up. Pry it up with a small pry tool or z shaped screwdriver if you need additional force.
Jim Adkins
PostPosted: Sat Oct 24, 2015 10:46 am    Post subject: Reply with quote
Grenadier….the relay under the dash next to the fuse panels. Roman numeral I, square shaped.
Jason C…..thanks for the thought on removing, will try with a small pry tool.
am wondering if it might be the relay on lower part of radiator? when I start it up the temp rises but it gets too hot before radiator cooling fans kick in and I need to shut it down which ain't good with it hot!!
Thanks guys
87' 924S, Red
PostPosted: Sat Oct 24, 2015 12:04 pm    Post subject: Reply with quote
Try smacking the top of the relay when the engine starts to get hot to see if the relay is just sticking.
jason c
PostPosted: Sat Oct 24, 2015 1:14 pm    Post subject: Reply with quote
Thanks guys
The part on the radiator that controls the fans on/off is the fan temp switch, its not a relay. You can test it by heating it in hot water while checking temp & for continuity. Compare your findings to the temp range on the switch. They do offer different temp ranges to make the fans come on earlier.
PostPosted: Wed Oct 28, 2015 12:38 pm    Post subject: Reply with quote
These temp gauges can be inaccurate, make sure it's reading correctly with one of these:
http://www.northerntool.com/shop/tools/product_200467177_200467177?cm_mmc=Bing-pla&utm_source=Bing_PLA&utm_medium=Construction%20%3E%20Thermometers&utm_campaign=Milwaukee&utm_content=19815&ci_src=328768002&ci_sku=19815
