chassis #99 Resto
Goto page 1, 2, 3  Next
pcelenta
PostPosted: Fri Sep 18, 2015 4:24 am    Post subject: chassis #99 Resto Reply with quote
Full gut out to a tub. The madness begins! Full restoration of a very rare car.
PostPosted: Fri Sep 18, 2015 4:40 am    Post subject: Reply with quote
Subscribed!
PostPosted: Fri Sep 18, 2015 4:41 am    Post subject: Reply with quote
Cool. Get the battery tray fixed yet?
pcelenta
PostPosted: Fri Sep 18, 2015 5:35 am    Post subject: Reply with quote
soon dave...we are gonna use your donor piece for sure. mine is just too thin to patch and the level of resto warrants a clean arizona piece!
kcoyle
PostPosted: Fri Sep 18, 2015 6:03 am    Post subject: Reply with quote
Gonna be looking good for sure!!
pcelenta
PostPosted: Fri Sep 18, 2015 6:19 am    Post subject: Reply with quote
in time kevin. hey you going up to old westbury gardens for the concourse Sept 27th?
kcoyle
PostPosted: Fri Sep 18, 2015 6:30 am    Post subject: Reply with quote
I have to see. I'm coaching fall baseball this year and I have both kids games that day starting at 1130. I'd love to stop by for a bit.
TJC
PostPosted: Sat Sep 19, 2015 12:32 am    Post subject: Reply with quote
Ahh...I can relate to that "bare tub" starting point! Enjoy and take plenty of photos along the way.
'95 BMW 318i/5 ..."Pearl"
'04 BMW X3..."Xander"
Still on the Prowl!
www.ttrs1.com
pcelenta
PostPosted: Fri Sep 25, 2015 5:05 am    Post subject: Reply with quote
rhinoplasty begun: too many bumps bruises and rust to save
PostPosted: Fri Sep 25, 2015 4:06 pm    Post subject: Reply with quote
Oh wow thats rusty !
That nose panel was surely replaced during her lifetime as it would be impossible that the nose panel rusted like that and the metal around it not.
So the nose panel was probably replaced and wirebrushed with no rust protection after.
pcelenta
PostPosted: Sat Sep 26, 2015 12:00 am    Post subject: Reply with quote
nahh. no evidence the nose was ever replaced. all the spot welds were original and no evidence of burn marks from prior spot welds. What I suspect is that because this is a very early turbo the nose panels were not yet galvanized. Still have to do some poking around on the panel to see..but that is the theory.
pcelenta
PostPosted: Tue Sep 29, 2015 1:04 am    Post subject: Reply with quote
here's some before and after waterboarding...I mean steam cleaning.
pcelenta
PostPosted: Tue Sep 29, 2015 1:06 am    Post subject: Reply with quote
after waterboarding:
pcelenta
PostPosted: Tue Sep 29, 2015 1:13 am    Post subject: Reply with quote
so now we have an idea what was under all that dirt and crust. Some things to note. my initial belief was that the modifications for the CGT flares was achieved by cutting the outer quarter low and the outer wheel tub high then rolling the quarter over the tub. Now that we are in there it is clear that entirely new outer wheel tubs were welded in to accomodate the flares. as most of you know that is a lot a work and not typically how we see CGT flares done. If you look at the after pictures you can see that the new outer wheel tubs were coated in a very tough black undercoating. more finding to follow.
pcelenta
PostPosted: Tue Sep 29, 2015 4:13 am    Post subject: Reply with quote
media blasting begun and some interesting finds:
look carefully and you can see 0099. the darker square part covers the 99 and was where the washer tank rubbed away the paint.
First off, these early turbos were "chosen" to be turbos early on in the raw body stage from amongst the NA cars and before the chassis number was stampped into the shock tower and the body plate added. Both the chassis number and the turbo indicator appear to have been made by a marker. It is unclear if this was on to the raw galvanized steel or on top of the primer but this was under the silver basecoat clear and became apparent upon media blastic.
Page 1 of 3
