924/924S Parts Interchangeability
Porsche77924
PostPosted: Sun Aug 16, 2015 1:19 pm    Post subject: 924/924S Parts Interchangeability Reply with quote
I have a '77 924 that I inherited and found an '87 924S locally for sale that I would like to use as a donor car for parts. I'm wondering what parts, if any, are interchangeable. Specifically, can I use the hubs to do a 5 lug conversion? Can I swap one trans for another? Heads?
Any help would be appreciated guys, thank you.
Stock '77 924 74XXX Miles
curtisr
PostPosted: Sun Aug 16, 2015 9:46 pm    Post subject: Donor data Reply with quote
Forgive me but, why not go the other way 'round? The '87 is a much 'better' car.
World's worst welder.
PostPosted: Sun Aug 16, 2015 10:47 pm    Post subject: Reply with quote
There is not much that will be directly transferrable between those cars.
For the five lug conversion, there is no easy way to transfer the alu-based rear trailing arm setup from the 87 into the 77 because the 77 torsion carrier is unique to the very early cars. The only way to do it requires welding / fabrication on the 77 torsion carrier.
The front spindle-hub-strut arrangement should be directly swappable.
The trans is not easily swappable. In order to do that, you would need to drop the entire torque tube, trans, and shift rod arrangement from both cars, which also involves removal of the torsion carrier from both cars. Then, you would need to replace the clutch disc in the 77 with a clutch disc from a 86 Ford Bronco II, which will fit into the early manual clutch pack and allow the early car to accept the larger 25mm driveshaft from the 87 car.
Virtually nothing from the engine or exhaust will be transferrable.
Seats, dash, door cards, carpet and many of the interior bits are transferrable, but there are nuances. For example, the upper rear seat portion and rear quarter liners are different...you can get them to go into the earlier car, but the mounting points are different at the chassis, which will require some modifications. Another example, the center console is not directly swappable without mods because the HVAC unit mounts completely differently. Again, it can be done, but requires some ingenuity.
Very little from the HVAC system is swappable.
Sun visors will be a nice upgrade. The "smooth" rain channels are as well, but require a bit of fabrication to swap. The windshield trim and many of chassis seals, particularly around the doors are a big upgrade and are swappable.
Depending on the price of the 87 parts donor, you might be better off looking for a 5-lug equipped 80-82 924 or 931.
curtisr
PostPosted: Mon Aug 17, 2015 3:45 am    Post subject: Reply with quote
^^^+1^^
My understanding is that the body bits can be swapped although the sunroofs were not identical in size. I have removed the fenders from my '77 Euro 924 to put on an '87 924s.
PostPosted: Mon Aug 17, 2015 8:20 am    Post subject: Reply with quote
I think the Sunroofs are the same physical size, but the latches are different because the 924S/944 used a power solution, while the early 924 used a manual latching solution.
One can retrofit the power roof with the manual latches, but it requires some work.
Porsche77924
PostPosted: Mon Aug 17, 2015 10:31 am    Post subject: Reply with quote
Thanks for the replies everyone.
To answer your question curtisr, the car was my father's and when he passed away it became mine. There may be 'better' cars but this one holds a lot of sentimental value to me.
Thanks for all the information ideola. Sounds like it would be a lot more hassel than the car is worth. It's for sale in Cherry Valley (I see you're from N Illinois) and was hoping it would be a hole in one for parts.
PostPosted: Mon Aug 17, 2015 10:43 am    Post subject: Reply with quote
Yep, Woodstock! You should come by the farm some time...PM me for coordinates if you're interested.
I know which car you're referring to...not an especially good candidate given the body damage and the fact that it has an Auto.
For the same asking price, this would be a much better candidate as a parts donor for your 77: http://peoria.craigslist.org/cto/5154060617.html
Porsche77924
PostPosted: Mon Aug 17, 2015 11:23 am    Post subject: Reply with quote
Definitely would like too! Looks like you've got an exceptional collection.
And that would make an excellent donor. Mine was unfortunately resprayed a different yellow than factory but those seats are in much better shape and I'm sure it has some other parts I'd swap.
