Looking for some Turbo Part Numbers
Knz
PostPosted: Wed Aug 12, 2015 3:38 am    Post subject: Looking for some Turbo Part Numbers Reply with quote
I'm trying to find part numbers for the two bolts for the turbo intake manifold, and the gasket that goes between the manifold and the part that is sitting on the turbo. If anyone could help me out with these, that would be awesome.
1980 931 (#185) for sale
1980 931 (#196) engine rebuild
1983 928S Project
1983 944 Summer Car
2002 BMW 525i Winter Car
View user's profile Send private message Visit poster's website Yahoo Messenger
PostPosted: Wed Aug 12, 2015 4:02 am    Post subject: Reply with quote
http://lmgtfy.com/?q=porsche+924+turbo+PET+download
PostPosted: Wed Aug 12, 2015 4:05 am    Post subject: Re: Looking for some Turbo Part Numbers Reply with quote
I have no idea what you are describing here...can you be a bit more specific? Are these bolts on the 931 intake manifold itself? If so there are *many* bolts, so when you say "the two", it's hard to know which two.
Assuming this is an S2 931, there are 4 seals between the turbo compressor outlet and the throttle body.
- compressor outlet to lower charge tube (red o-ring)
- lower charge tube to upper charge tube (green paper gasket)
- upper charge tube to throttle body, inner o-ring (red o-ring)
- upper charge tube to throttle body, outer rubber seal (black, and no longer available)
Is it one of these you're thinking of?
Knz
PostPosted: Wed Aug 12, 2015 4:22 am    Post subject: Reply with quote
sorry, I am very bad with part names, I've never had any mechanical training and have been just learning as I go..
I was talking about the pressure pipe apparently.
Thank you CarreraRSR, while it wasn't the exact parts, those PET (what does that stand for?) diagrams are very helpful
it seems I will be trying to source the following parts for my S1 turbo:
928 110 363 01 - air box strap - 2x
999 701 473 40 - round seal - 1x
931 110 405 00 - rubber sleeve - 1x
931 110 152 01 - turbo gasket - 1x
N 010 313 4 - turbo manifold bolt - 1x
N 010 366 4 - turbo manifold bolt - 1x
N 012 226 5 - trbo mnfld bolt wash - 2x
is the N part of the part number?
1983 928S Project
1983 944 Summer Car
PostPosted: Wed Aug 12, 2015 4:41 am    Post subject: Reply with quote
Yes.
Can I give you a quote for that list?
rc7424
PostPosted: Tue Sep 01, 2015 10:46 am    Post subject: Reply with quote
If you are looking for the bolts, washers and gasket to connect the upper pressure pipe to the lower pressure pipe that connects to the turbocharger look here:
http://www.autoatlanta.com/porsche-parts/hardparts.php?dir=924-80-85&section=107-30
You need numbers 9 through 12. You can bypass the dealer for the bolts & washers. The sizes are listed and they are widely available.
__________________________
Autonomous Vehicles are for Automonous People
'82 931
'22 Alfa Giulia
'21 BMW 840
'02 Ducati 998
'11 FXDWG
'75 Honda 750 F
