hjlew
Posted: Fri May 29, 2015 1:16 am Post subject: Automatic tranny damper plate replacement |
Hi all I am looking for some assistance/ directions on how to replace the damper plate in my '87 924s. I have purchased several books but not much info to help. Thanks _________________ '87 924S
'67 Datsun 1600
'69 Datsun 2000 |
KDJones2000
Posted: Fri May 29, 2015 3:41 am Post subject: |
Look in Clark's Garage for a write up. Not sure if he covers the automatics, but much of it is the same, other than you have a clamp up near the damper on the torque tube that has to be dealt with.
I have never worked on automatics, so not sure of the details.
www.clarks-garage.com
Look under Garage Shop Manual _________________ 1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S |
hjlew
Posted: Fri May 29, 2015 5:56 am Post subject: |
I will look thanks for the information _________________ '87 924S
'67 Datsun 1600
'69 Datsun 2000 |
edredas
Posted: Fri May 29, 2015 6:08 am Post subject: |
Here's a direct link to the page that KD is referring to.
http://www.clarks-garage.com/shop-manual/clutch-01.htm
Also, due to the expense of the damper, some have swapped in clutch. It is a cheaper solution; and while I've also never worked on an auto, I have sold a few old clutches for that purpose. _________________ '84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver |
jason c
Posted: Sat May 30, 2015 6:46 pm Post subject: |
| The biggest difference is the way the clutch & the damper are attached. On the automatic, you remove the bolts that attach the damper to the flex plate, leave the damper attached to the driveshaft, move the TT back & then you can remove the damper from the driveshaft. There is a clip holding it on. The procedure for removing the clutch disk won't work for the automatic. |
edredas
Posted: Sun May 31, 2015 2:50 am Post subject: |
| jason c wrote: | | The biggest difference is the way the clutch & the damper are attached. On the automatic, you remove the bolts that attach the damper to the flex plate, leave the damper attached to the driveshaft, move the TT back & then you can remove the damper from the driveshaft. There is a clip holding it on. The procedure for removing the clutch disk won't work for the automatic. |
All he needs to know is how to remove the coupler like KD already mentioned. There appears to be a bolt holding it in place, not a "clip. After that, the rest is exactly like doing a clutch, but easier since you won't have to mess with the fork.
Also, where is this "flexplate" that he needs to remove bolts from? _________________ '84 944 -White, Brown interior
jason c
Posted: Sun May 31, 2015 8:14 am Post subject: |
| edredas wrote: | | jason c wrote: | | The biggest difference is the way the clutch & the damper are attached. On the automatic, you remove the bolts that attach the damper to the flex plate, leave the damper attached to the driveshaft, move the TT back & then you can remove the damper from the driveshaft. There is a clip holding it on. The procedure for removing the clutch disk won't work for the automatic. |
Also, where is this "flexplate" that he needs to remove bolts from? |
The clip is #25, you can't slide the driveshaft out of the assembly with it on.
"Flexplate" is another term for flywheel on an automatic, it is bolted to the crankshaft (neither are shown). |
