Experiment MKUltra...
PostPosted: Wed May 27, 2015 7:27 am    Post subject: Experiment MKUltra... Reply with quote
I have the rear way up in the air eyeballing a shift bushing job + while I'm in there stuff..
As you all can probably tell by now my mind works in strange ways and I ended up measuring the torque it takes to slip the G31 LSD (to get the wheels move opposite) in 1st gear..
After a crows foot formula to rectify for the distance from the lugs to centerline of the axle (which didn't make much difference) It comes out to about 60 ft/lbs it takes to make it slip, or 65 ft/lbs on an outside lug inline with the tool.. Seems low?
I just thought it was an interesting thing to quantify about an interesting piece that I haven't seen done before...
I suppose it could be compared to others for wear and/or different oil characteristics and their effect on the clutches.. 70k miles and redline MT90 full synth here..
Sorry if I'm too out of the box for you guys, I don't mean to just fill the board with stupid crap but I get bored..
80 Turbo - Slightly Modified
PostPosted: Wed May 27, 2015 9:43 am    Post subject: Reply with quote
Wrong oil, too slippery?
PostPosted: Wed May 27, 2015 10:14 am    Post subject: Reply with quote
Maybe... It feels like nobody ever installed a 2nd gear synchro, no grind in 1st but I get like a block out where it won't go in sometimes and tricks me..
I got MT90 because many here recommended it.. Read some 911 guys say synth is too slippery and they prefer dino.. I have a bunch of cheap 75-90 napa dino on hand I could switch in and give a try...
You think I should give it a shot?
PostPosted: Wed May 27, 2015 11:26 am    Post subject: Reply with quote
MT90 requires use of a friction modifier for a clutch type LSD.
PostPosted: Wed May 27, 2015 11:28 am    Post subject: Reply with quote
Could you point me to a recommended product? Would said friction modifier have any effect on syncros?
looking... http://www.redlineoil.com/product.aspx?pid=41&pcid=4
PostPosted: Wed May 27, 2015 2:48 pm    Post subject: Reply with quote
P.S. Per FSM, breakaway torque for G31 LSD is 25 to 43 ft lb.
PostPosted: Wed May 27, 2015 3:36 pm    Post subject: Reply with quote
I get the same with my 931 G31, sometimes it just wont go in first. No crunch, just its like the gear is locked and cant be engaged. I figured its either a clutch problem or a linkage problem.
PostPosted: Wed May 27, 2015 4:21 pm    Post subject: Reply with quote
Wow, I'm not doing too bad then eh? Thanks for the good news!!! For once..
I really need to check the trans code one of these days to see if it has the lsd designation number or not..
PostPosted: Wed May 27, 2015 4:26 pm    Post subject: Reply with quote
Check this sweet geeky synchronizer video out, I really like this one...
https://www.youtube.com/watch?v=MXsRfbOiBhE
PostPosted: Wed May 27, 2015 4:57 pm    Post subject: Reply with quote
Strange, I have the same engaging first sometims. Though i have new syncros, dog ring, linkage bushings, hydraulic cylinders etc.
PostPosted: Wed May 27, 2015 6:34 pm    Post subject: Reply with quote
Do you actually have the new gear hosing? So the brass coloured part?
Maybe those 3 locking keys are worn..
PostPosted: Thu May 28, 2015 5:38 am    Post subject: Reply with quote
3102 1674 /12
So its probably factory..
