crank gilmer pulley bolt torque
kpasko
PostPosted: Tue May 19, 2015 3:25 pm    Post subject: crank gilmer pulley bolt torque Reply with quote
Just popped the timing pulley back on after oil pump work (and just a superbly jolly time getting the bolt in question off...), but alas my puny. 5" torque wrench is only rated to 150ftlb, and I noticed the haynes has that bolt spec'd at 180...
Is 150 good enough for amateur hour over here, or highly recommended to source a (potentially one-time-use) torque wrench that's a bit more "persuasive" to get the full 180?
Thanks,
K
leadfoot
PostPosted: Wed May 20, 2015 8:07 am    Post subject: Reply with quote
Turbo need it done correctly n/a depends if your ever doing rear suspension work, there are a few bolts around the car with high torque so it might be worth investing? Other options are borrowing one from; tool hire, friend or down to the mechanics in you shortest skirt and working those legs, normally their pretty happy if you pick a quiet day for this or get them first thing in the morning, the trick being to drop your purse alot and pick it up not bending the knee...
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
