Substitute for 40cc fuel accumulator for 1981 924
Johnny_Haywire
PostPosted: Tue Apr 28, 2015 12:26 pm    Post subject: Substitute for 40cc fuel accumulator for 1981 924 Reply with quote
Hey guys,
Finally going to have some time and some warm weather to go through the fuel system on my '81 924. It's been a cruel winter here in Chicago and not much of a spring yet, either.
All that said, I'm going to try and replace as much of the fuel system rubber hoses as possible and also my accumulator.
Found this accumulator on eEuroparts for $76.49:
http://www.eeuroparts.com/Parts/53589/Fuel-Injection-Fuel-Accumulator-0438170001/?gclid=CMbQvfvvl8UCFYQAaQod_oEAtg
Bosch 0438170001
Anyone have any experience using one of these? I'm curious as to whether the fittings will match up. I have the single (what I believe is a 40cc accumulator in my 1981 US model).
1981 924 N/A 5-speed
gerben1986
PostPosted: Wed Apr 29, 2015 4:05 am    Post subject: Reply with quote
If I have a look on the fittings it looks like there's a smaller and a bigger one. I guess on your current car both fittings have the same size.
Check also this topic: http://www.924board.org/viewtopic.php?t=40975
911SC - 1980
Johnny_Haywire
PostPosted: Wed Apr 29, 2015 9:45 am    Post subject: Reply with quote
I believe you are right, that mine has the two same size fittings. Thank you for pointing that out.
Well, it was worth a look. I will double check when I remove mine, but was hoping an Audi or VW part would work.
One last thought - could an adapter be fitted to one of the fittings on this Bosch unit to work with the 924 hoses?
gerben1986
PostPosted: Wed Apr 29, 2015 4:11 pm    Post subject: Reply with quote
Good question, take also into consideration that the flowrate of a smaller fitting will be lower, and if that will cause problems when hitting the pedal
On the otherside, it would really save money, because a new one for th 924 is really expensive...
911SC - 1980
PostPosted: Wed Apr 29, 2015 5:58 pm    Post subject: Reply with quote
I recently bought the 40cc 924 accumulator. Its not extremely expensive at 127 usd. Although not that fun part to put your money into
