RicardoRJL1
Joined: 09 Feb 2011 Posts: 22 Location: San Jose, Costa Rica
Posted: Sat Feb 14, 2015 4:07 am Post subject: Transmission oil and issue? |
Good day everyone.
I wonder if you could help me with a question?
We where working on my torque tube and clutch, but the mechanic (now ex-mechanic) forgot to put in transmission oil. I run the car this way for about 1 mile, maybe a bit more, without knowing there was no oil.
I had to do some work on the torque tube bearings due to the sloppy work of this ex-mechanic, the torque tube is now fixed, but before putting in the torque tube and gearbox...
I just wan't to know if the transmission could be damaged for running it without oil? Besides the obvious wich is opening the gearbox, is there any other way to tell if it's damaged?
Thanks !!
RicardoRJL1
Posted: Sat Feb 14, 2015 4:08 am Post subject: |
| The gears engange properly when done manually. |
Posted: Sat Feb 14, 2015 4:12 am Post subject: |
Put oil in and drive it...best way to tell. _________________ Toofah King Bad
RicardoRJL1
Posted: Sat Feb 14, 2015 4:20 am Post subject: |
I'm going on that direction, hopefully nothing happened to it.
Trusting german engineering  |
Posted: Sat Feb 14, 2015 6:58 am Post subject: |
| I'd put oil in it and drive it **a little bit**. Then drain the oil and look for metal. If none, refill and off you go. If you find bits of metal and gear teeth, well, that's not as good of course. |
daniel
Posted: Sat Feb 14, 2015 12:31 pm Post subject: |
Unlikely, there would still be a film of oil on internals which would protect for a short while _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
RicardoRJL1
Posted: Wed Mar 25, 2015 1:54 am Post subject: |
Well, I couldn't resist and just to be safe...
Two synchronizer insters where broken
So i'm going to "refresh" everything, check for any further faults...
