Boost gauge connection
fwood
PostPosted: Tue Feb 10, 2015 12:44 pm    Post subject: Boost gauge connection Reply with quote
Would it work to connect a Vdo vacuum/boost gauge with a t fitting to the control line to the ditc unit.
Frank
PostPosted: Wed Feb 11, 2015 3:43 am    Post subject: Reply with quote
If that control line is manifold vacuum, yes.
jason c
PostPosted: Wed Feb 11, 2015 6:26 am    Post subject: Reply with quote
You can if you have the small gauge. I'm not sure that that line is big enough for the larger 935 style gauge. The DITC control may also have a delayed reaction from the extra line added that it must fill before full pressure reaches it. The dealer installed boost gauge kits tied in to the manifold or upper pressure duct with its own dedicated line.
fwood
PostPosted: Wed Feb 11, 2015 9:55 am    Post subject: Reply with quote
Thanks for that input. I got a small gauge to go in place of the inoperative clock and thought that putting a T in the cabin next to the ditc would be low impact. I did not want to try to machine another access point on the intake path. Just wanted to see boost in action!
Frank
jason c
PostPosted: Wed Feb 11, 2015 10:02 am    Post subject: Reply with quote
You can get a longer bolt & put 2 eyelets on it, one for DITC & one for the gauge. No machining needed.
fwood
PostPosted: Wed Feb 11, 2015 10:09 am    Post subject: Reply with quote
Where do you get those?
Frank Wood
82 931
PostPosted: Wed Feb 11, 2015 10:30 am    Post subject: Reply with quote
Lindsey Racing sells them, but anyplace that carries barbed metric banjo fittings
http://www.lindseyracing.com/LR/Parts/944INTMANMISC.html
jason c
PostPosted: Wed Feb 11, 2015 10:54 am    Post subject: Reply with quote
You'll need 3 crush washers too.
PostPosted: Wed Feb 11, 2015 12:46 pm    Post subject: Reply with quote
Absolutely zero wrong with doing it that way.
DZGunner
PostPosted: Wed Feb 11, 2015 2:13 pm    Post subject: Reply with quote
sorry but what does DITC stand for, thanks
jason c
PostPosted: Thu Feb 12, 2015 2:17 am    Post subject: Reply with quote
Digital Ignition Timing Control. Its used on 1981-on 931.
The control unit controls the ignition timing & has the ability to change timing based on boost pressure. There is a pressure switch in the control unit that is fed intake vacuum/pressure via a hose from the intake.
Fwood would like to tap into this line for a boost gauge.
DZGunner
PostPosted: Thu Feb 12, 2015 3:34 am    Post subject: Reply with quote
Oh, makes sense. I have an 80 and am doing the same, it's just I put a T in one of the lines that is before the venturi tube. The big elbow connected Directly to the manifold on the top (the only one) leads right to the one I T'd into so I think it should work.
jason c
PostPosted: Thu Feb 12, 2015 4:21 am    Post subject: Reply with quote
Any line that is connected to the intake & is large enough to supply the gauge will work. The small vdo gauges don't need a large supply line. You will not get a vacuum signal if its before the throttle body though.
The reason I cautioned about tapping into the DITC line is because the line supplies a pressure switch in the DITC that determines the timing advance/retard based on boost pressure. A bleed off from that line may affect the reaction time of the DITC.
Your car does not have this line or DITC.
