Ignition 924 turbo s1
Pascal924
PostPosted: Thu Dec 25, 2014 7:22 pm    Post subject: Ignition 924 turbo s1 Reply with quote
Hello Porsche friends.
Iam new on This form, but u follow your post already for Many years.
I am a Porsche enthousiast from the netherlands, and i
restored Porsches for my hobby.
For the moment my collection consistent 4 classic 911 and 2 924 turbo's with gt kit.
For my latest project i have questions about the ignition of an 924 turbo s1.
I have a gt carrera intercooler, so u want to upgrade the engine ril 1.0 bar turbo pressure.
I want to use the mittelmotor or 123 ignition option...
I have read that some of you tried This, but it is not clear for me if it was succesfull...
Thanks for your feedback.
PostPosted: Thu Dec 25, 2014 8:06 pm    Post subject: Reply with quote
You don't really need other ignition if you run 1bar with an intercooler.
its a good way to upgrade but in my opinion not really necessary.
PostPosted: Thu Dec 25, 2014 9:22 pm    Post subject: Reply with quote
The advance/retard of the stock dizzy isn't optimized for IC and 1.0 bar. It can be recalibrated but still not too effective in avoiding knock. I had knock at 0.9-1.0bar.
The CGT top mounted IC may not cool the intake enough to reliably run 1.0bar without knock. I'd recommend a knock sensor/warning
Take a look at my thread below as I'm running the Mittelmotor dizzy successfully. But I'm struggling to go too far north of 1.0 bar even with CGT turbo and front mounted 944 IC but more mods are on their way to help.
Pascal924
PostPosted: Fri Dec 26, 2014 1:19 am    Post subject: Reply with quote
So what turbo pressure do you have?
I think i need a other dizzy because the vacuümbox is in the way.
Perhaps a normal turbo curve in the 123 ignition be perfect...
I want to have a bit more hosepower, but it must be reliable, and i want to have some advantage from the intercooler.
How much hp do you make.
I have seen, you strugle with the head gasked...
Tanks for your reply...
PostPosted: Fri Dec 26, 2014 6:01 pm    Post subject: Reply with quote
So the S1 is much more agressive in advance to make up for lower compression?
PostPosted: Fri Dec 26, 2014 7:09 pm    Post subject: Reply with quote
Running up to 1.0bar and circa 220-230 bhp. It did peak higher on the dyno.
Head gasket issues were due to issues with my head. Replacement head is being rebuilt currently.
Speak to Michael at Mittelmotor regarding maps for their dizzy. He's very helpful and will load up options for you which worked for their cars. You can run two alternative maps and switch between them
924-76
PostPosted: Tue Jan 13, 2015 8:29 pm    Post subject: Reply with quote
Welcome to the board
The 924 Carrera GT is running at 12lbs boost.
I also have a GT intercooler and currently set at 10lbs and still running stock distributor and ignition.
I'm planning on increasing to 12lbs when everything else is sorted.
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
Pascal924
PostPosted: Sun Jan 25, 2015 6:54 am    Post subject: Reply with quote
I Spoke to mittlemotor and they could give a good and reliable solution.
I think if you want a more efficiënt engine with more hp, you need to have an other curve. 1 bar is more les the limit with the top mounted intercooler. Probably somewere between 0.85-0.9 should be perfect with the mittlemotor dissy.
I dont know if it worth to invest in a special/sharper camshaft?
