Intake Manifold Compatability Question
FUN2DRV
PostPosted: Wed Dec 10, 2014 8:36 am    Post subject: Intake Manifold Compatability Question Reply with quote
I recently picked up a 1981 931 that suffered a broken timing belt. The head has already been repaired and is ready to go back on, but the intake manifold was cracked on all four runners. The PO had the manifold welded but it doesn't look so good and it will require machining to remove the excess weld and provide a flat/smooth sealing surface.
My question is, will an intake from a 1980 931 fit on the 1981 931?
I have an opportunity to pick up an intake from a 1980 and want to make sure it will fit prior to purchasing.
The PET lists a 931 110 059 01 (M31.01/02) without calling out a year, and 931 110 059 05 (M31.03/04/50) for 1981.
Thanks,
'81 931
'87 944 N/A
FUN2DRV
PostPosted: Wed Dec 10, 2014 9:23 am    Post subject: Reply with quote
Never mind, I found my answer here:
http://www.924.org/parts/parts.htm
'81 931
'87 944 N/A
PostPosted: Wed Dec 10, 2014 10:11 am    Post subject: Reply with quote
The throttle body is different between the two and you'll want to keep the later throttle body since it can be rebuilt to alleviate the common shaft leaks that happen over time. You might be able to adapt it, but then the boost pipe won't fit, etc.
I am curious how they managed to break the manifold.
PostPosted: Wed Dec 10, 2014 5:39 pm    Post subject: Reply with quote
Gravity assist.
FUN2DRV
PostPosted: Wed Dec 10, 2014 8:33 pm    Post subject: Reply with quote
Rasta Monsta wrote:
Gravity assist.
This would be my guess, I will have to ask again when I go to pick up the car. When I was looking at it the PO said it was cracked when he took it off.
'81 931
'87 944 N/A
PostPosted: Wed Dec 10, 2014 8:54 pm    Post subject: Reply with quote
obviously, he took it off after he hoisted the engine out by it, and prior to that, of course cleverly dismantling its strengthening sheet metal bracket.
FUN2DRV wrote:
Rasta Monsta wrote:
Gravity assist.
kcoyle
PostPosted: Wed Dec 17, 2014 3:19 am    Post subject: Reply with quote
Saw this s2 car being parted out in Springfield MA on the CL which has what you need.
http://westernmass.craigslist.org/ptd/4798960960.html
FUN2DRV
PostPosted: Mon Dec 22, 2014 1:27 am    Post subject: Reply with quote
Thanks, I saw that too, I will be contacting them.
'81 931
'87 944 N/A
