FUN2DRV
Posted: Wed Dec 10, 2014 8:36 am Post subject: Intake Manifold Compatability Question |
I recently picked up a 1981 931 that suffered a broken timing belt. The head has already been repaired and is ready to go back on, but the intake manifold was cracked on all four runners. The PO had the manifold welded but it doesn't look so good and it will require machining to remove the excess weld and provide a flat/smooth sealing surface.
My question is, will an intake from a 1980 931 fit on the 1981 931?
I have an opportunity to pick up an intake from a 1980 and want to make sure it will fit prior to purchasing.
The PET lists a 931 110 059 01 (M31.01/02) without calling out a year, and 931 110 059 05 (M31.03/04/50) for 1981.
Thanks, _________________ '81 931
'87 944 N/A |
FUN2DRV
Posted: Wed Dec 10, 2014 10:11 am Post subject: |
The throttle body is different between the two and you'll want to keep the later throttle body since it can be rebuilt to alleviate the common shaft leaks that happen over time. You might be able to adapt it, but then the boost pipe won't fit, etc.
I am curious how they managed to break the manifold. _________________ Stefan
Posted: Wed Dec 10, 2014 5:39 pm Post subject: |
| fiat22turbo wrote: | | I am curious how they managed to break the manifold. |
Gravity assist. _________________ Toofah King Bad
FUN2DRV
Posted: Wed Dec 10, 2014 8:33 pm Post subject: |
| Rasta Monsta wrote: | | fiat22turbo wrote: | | I am curious how they managed to break the manifold. |
Gravity assist. |
This would be my guess, I will have to ask again when I go to pick up the car. When I was looking at it the PO said it was cracked when he took it off. _________________ '81 931
'87 944 N/A |
Posted: Wed Dec 10, 2014 8:54 pm Post subject: |
obviously, he took it off after he hoisted the engine out by it, and prior to that, of course cleverly dismantling its strengthening sheet metal bracket.
| FUN2DRV wrote: | | Rasta Monsta wrote: | | fiat22turbo wrote: | | I am curious how they managed to break the manifold. |
Gravity assist. |
This would be my guess, I will have to ask again when I go to pick up the car. When I was looking at it the PO said it was cracked when he took it off. |
_________________ Supercharger and EFI kits
kcoyle
Posted: Wed Dec 17, 2014 3:19 am Post subject: |
Saw this s2 car being parted out in Springfield MA on the CL which has what you need.
http://westernmass.craigslist.org/ptd/4798960960.html _________________ 1982 931- Stock with MBC at 8psi
FUN2DRV
Posted: Mon Dec 22, 2014 1:27 am Post subject: |
Thanks, I saw that too, I will be contacting them. _________________ '81 931
'87 944 N/A |
