AFR Gauge/values
Lau Christophersen
PostPosted: Thu Dec 04, 2014 8:43 am    Post subject: AFR Gauge/values Reply with quote
I recently finished my new exhaust including a wide band censor and a AFR gauge.
The problem I find is that it shows good values (11,2-11,3) when at idle, but as soon as i touch the pedal it goes out of scale(above 1 when hitting boost it goes down again into scale and when on full boost goes in the "green area"(good values) again.
If i drive at steady speed the value is around 17,2.
Is the problem a vacuum leak or? I was testing all vacuum connections for leaks and could not find any.
Any good ideas? I can feel it is going to lean and I dont drive any more before i find the problem.
PostPosted: Thu Dec 04, 2014 4:44 pm    Post subject: Reply with quote
Sounds weird, should look something like this:
Ive just tried two different 931s but both of them were around these values. Cruise was around stoich, 14,7.
When I had a broken WUR the car ran 12-13 at full load (cant remember exactly), that made the knock sensor light up, until I swapped in a working one. and everything went fine ever since
PostPosted: Thu Dec 04, 2014 8:12 pm    Post subject: Reply with quote
I'd recommend placing a known accurate AFR sensor in the tail pipe and running both gauges in tandem so you know they are both working with similar values. Don't assume your gauge and sensor are good until verified.
Lau Christophersen
PostPosted: Thu Dec 04, 2014 11:44 pm    Post subject: Reply with quote
Thank you for answers
I just dont understand that it goes fine with heavy boost and at idle but too lean between these to situations.
Any idea of how many hp a stock euro 931 with FMIC makes with 1,4 bars boost?
PostPosted: Fri Dec 05, 2014 12:17 am    Post subject: Reply with quote
Perhaps you forgot to calibrate it ?
Or you messed up the calibration.
Read the instructions, you have to power it and leave it in open air for a while if I remember correctly.
PostPosted: Fri Dec 05, 2014 2:15 am    Post subject: Reply with quote
Should be approaching 300, but not for long.
Also, your fuel curve doesn't make sense. Too rich at idle and too lean at cruise?
Lau Christophersen
PostPosted: Fri Dec 05, 2014 2:50 am    Post subject: Reply with quote
Just Asking because it was at that level when I bought the car now it is back at stock boost at 0,7 bar.
PostPosted: Fri Dec 05, 2014 4:29 pm    Post subject: Reply with quote
If its an euro car I would be a bit more optimistic about the HP figures.
The 924 Carrera GTS made 245hp at 1.1 bar and if i'm not mistaken 285hp in the CS version at 1.2bar. From 1.0bar upwards gains are more substantial with 0.1increments of boost than under 1.0bar.
For example, it looks like 1.2bar over 1.1bar will give you 40hp on the 924 turbo engine. While 0.8bar over 0.7bar will not give you 40hp.
I remember when the wastegate boot failed on mine, clouds of black smoke and such torque that it would squat the rear suspension completely.
It will not hold for long at those power levels, headgasket fails, but with some investments it will hold.
PostPosted: Fri Dec 05, 2014 11:02 pm    Post subject: Reply with quote
Stock turbo CIS will not support 250bhp+, nor will the stock turbo at 1.0bar+. But we all knew that already!!
Lau Christophersen
PostPosted: Sat Dec 06, 2014 2:27 am    Post subject: Reply with quote
But my boost gauge showed 1,4-1,5 bars, so the turbo can make that pressure?
PostPosted: Sat Dec 06, 2014 2:54 am    Post subject: Reply with quote
Turbo =/= CIS
The turbo can be overspun to produce a bunch of boost, but the fuel system won't support it and you'll risk seriously damaging the motor (the 931's seem prone to cracking rings anyway).
PostPosted: Sat Dec 06, 2014 4:19 am    Post subject: Reply with quote
Unless someone shows me that the cis afr screw is turned all the way to the max, boost gauge showing 1.4bar and wideband gauge showing lean conditions i wont believe the cis is limited to 250hp.
I'm running more mixture than stock 931 with a k27, reading afr of 10 at 1.1bar. When i installed a wideband i saw i was drenching the engine with 8 and 9afr at the same boost levels. I really think that cis can deliver serious amouns of fuel.
PostPosted: Sat Dec 06, 2014 4:48 am    Post subject: Reply with quote
When I fit my new head I'll test this theory of screwing in for super rich mixture and crank the boost North of 1.2 bar and I'll see what happens. I'll be sure to run the video as well so we can all giggle at the results
PostPosted: Sun Dec 07, 2014 1:45 am    Post subject: Reply with quote
Be careful, eyes on the afr and on the road.
