Tanso
Posted: Thu Nov 06, 2014 8:34 am Post subject: |
UPDATE
We are waiting for the main bearings so we started renewing all the brake lines.
Bought some universal copper brake lines.
And a special tool!
Looking good
Almost done with all the lines. We have to fit new rear brake cylinders first. The parts have arrived so thats the next step.
 _________________ Our 1983 Porsche 924 project: http://www.924board.org/viewtopic.php?p=364034#364034 |
RPM2006
Joined: 29 Dec 2009 Posts: 16 Location: Sweden, Stockholm
Posted: Fri Nov 07, 2014 3:56 am Post subject: |
Jobba på
Själv letar jag kolvar till 931an.. |
Posted: Fri Nov 07, 2014 4:46 am Post subject: |
Looks great, i need to do the same on both of my cars, one does not need it but it looks like fun. _________________ Supercharger and EFI kits
MikesCoupeGT
Joined: 18 Oct 2006 Posts: 474 Location: Ontario Canada
Posted: Sat Nov 08, 2014 12:00 am Post subject: |
You are doing a great job with that car. I did brake lines front to back on an Audi Coupe GT once. Not a fun job getting all the bends right. You have a great touch. Again Well done. _________________ Cheers;
MikesCoupeGT
'76 924
'83 944
''19 Elantra GT N-Line |
Johnny_Haywire
Posted: Sat Nov 08, 2014 6:37 pm Post subject: |
This is a great and engaging thread, Tanso. Many thanks for posting and also for all the great pics!
I'm curious about any accommodations that need to be made when removing 1.5mm from the head and also the power increase you expect to be gained.
Looking forward to your progress! _________________ 1981 924 N/A 5-speed |
Tanso
Posted: Sun Nov 09, 2014 8:57 am Post subject: |
| Johnny_Haywire wrote: | This is a great and engaging thread, Tanso. Many thanks for posting and also for all the great pics!
Looking forward to your progress! |
Nice to hear that you like our thread
We removed 1.5mm from the block, not the head. You cannot deck the head to increase compression beacuse of the design.
You have to remove the block from the engine compartment so that is a big job.
There is a guy here in sweden that removed 1.5mm and he went from 125hp to 138hp.
Compression is raised from 9.3:1 to 10.7:1. _________________ Our 1983 Porsche 924 project: http://www.924board.org/viewtopic.php?p=364034#364034 |
BBC1964
Posted: Mon Nov 10, 2014 11:45 am Post subject: |
| Great thread, and great pics. |
macBdog
Posted: Mon Nov 10, 2014 1:24 pm Post subject: |
Are those copper brake lines or is it a coating on steel?
Copper would be much easier to form the ends on, I've worn a few tools out making steel ends. _________________ 1979 931 with a 350 chev
1973 911E with EFI
MikeDanger
Posted: Mon Nov 10, 2014 1:30 pm Post subject: |
| Tanso wrote: | | Johnny_Haywire wrote: | This is a great and engaging thread, Tanso. Many thanks for posting and also for all the great pics!
Compression is raised from 9.3:1 to 10.7:1. |
which is why I have this thinner than stock Copper headgasket for sale  _________________ It was either this or a giant box of legos |
Johnny_Haywire
Posted: Mon Nov 10, 2014 2:56 pm Post subject: |
Ah, duly noted, take away from the block, not the head. And the timing belt tensioner is capable for correcting for this? The increase in power sounds quite nice.
I look forward to your progress.
Cheers from Chicago!
- Paul _________________ 1981 924 N/A 5-speed |
Tanso
Posted: Tue Nov 11, 2014 1:12 am Post subject: |
| BBC1964 wrote: | | Great thread, and great pics. |
Thank you!
| macBdog wrote: | Are those copper brake lines or is it a coating on steel?
Copper would be much easier to form the ends on, I've worn a few tools out making steel ends. |
Yes, those are copper brake lines. Not steel.
| Johnny_Haywire wrote: | Ah, duly noted, take away from the block, not the head. And the timing belt tensioner is capable for correcting for this? The increase in power sounds quite nice.
- Paul |
It is the cheapest way to increase performance in a 924! The tensioner corrects itself
| RPM2006 wrote: | Jobba på
Det ska vi! Måste vara svårt att hitta kolvar till en 931.
| morghen wrote: | | Looks great, i need to do the same on both of my cars, one does not need it but it looks like fun. |
It is quite fun doing the brake lines actually.
| MikesCoupeGT wrote: | | You are doing a great job with that car. I did brake lines front to back on an Audi Coupe GT once. Not a fun job getting all the bends right. You have a great touch. Again Well done. |
Thank you very much! It takes some time doing it but it looks really nice when done. _________________ Our 1983 Porsche 924 project: http://www.924board.org/viewtopic.php?p=364034#364034 |
Tanso
Posted: Sat Nov 15, 2014 11:27 pm Post subject: |
UPDATE
We continue with the brakes starting with the drums.
Comparing with the old ones during installation.
New fresh brake cylinders. Simplifies bleeding.
Applying some copper grease.
Continues with installation.
Looking good
But the drums are ugly.
Found some yellow brake paint.
Last step is to install the new brake line to the new cylinder
Next up is the front brakes _________________ Our 1983 Porsche 924 project: http://www.924board.org/viewtopic.php?p=364034#364034 |
Posted: Sun Nov 16, 2014 2:27 am Post subject: |
Next time you might think about knocking the rust off of the steel components and painting them as well. . . _________________ Toofah King Bad
Tanso
Posted: Tue Dec 09, 2014 4:06 am Post subject: |
UPDATE
We got our new main bearings from Mittelmotor in stock size!
But before we install these we need to lighten the flywheel and balance the engine. We hope to do that next week.
We are also done with the front brakes. Here is the pics!
Punching out the retaining pins.
Pulling out the old brake pads.
Loosening the 2 big nuts on the caliper.
Now we change to new gaskets.
We painted the calipers to. We are changing the color scheme to red instead of yellow. We are going to repaint the rear drums later.
Now we are putting it all together.
New brake pads.
Applying some copper paste.
Now we only have to fill the system with brake fluid! _________________ Our 1983 Porsche 924 project: http://www.924board.org/viewtopic.php?p=364034#364034 |
Johnny_Haywire
Posted: Tue Dec 09, 2014 4:26 am Post subject: |
Glad to hear the bearings have arrived. Nice progress with the brakes, too! _________________ 1981 924 N/A 5-speed |
