Goto page Previous  1, 2
PostPosted: Thu Jul 17, 2014 6:22 am    Post subject: Reply with quote
One thing to point out with the 5-lug conversion...
I fully endorse doing this conversion, especially on a car that has no historical significance and will never be a concours or restoration candidate. It's such an easy thing to do to improve the enjoyment of the car, it's almost a no-brainer in my mind.
However. The price point mentioned above is just to get the necessary used components. I would strongly urge you to replace all of the bearings at all four corners, to replace all of the rubber flex lines (either with new OEM rubber or stainless braided), and of course, you'll almost certainly need to replace the rotors (in my experience, used rotors are almost never serviceable). So you will be looking at quite a bit more money than the initial $200 or so to acquire the bolt-on bits. And that assumes you get a decent set of calipers and a decent master cylinder where the seals haven't dried up (again, a real long shot with used stuff that's been removed from a parts car). There's no way it will be cheaper than refurbing your four lug. Not trying to dissuade you, but you should go in with your eyes open.
ThomasJoseph315
Guest
PostPosted: Thu Jul 17, 2014 6:55 am    Post subject: Reply with quote
Last edited by ThomasJoseph315 on Sat Dec 12, 2015 6:04 am; edited 1 time in total
SlayerSST
PostPosted: Thu Jul 17, 2014 7:56 am    Post subject: Reply with quote
Quote:
I got $200 in my pocket right now,.. where do I get this set up?
Dude, you live in LA, figure it out yourself.
HINT: Junkyard
ThomasJoseph315
Guest
PostPosted: Thu Jul 17, 2014 10:47 am    Post subject: Reply with quote
SlayerSST
PostPosted: Thu Jul 17, 2014 11:46 am    Post subject: Reply with quote
Its your money, do whatever you want.
But remember, you have a 924 N/A not a 911.
ViktorTsoi
PostPosted: Thu Jul 17, 2014 2:28 pm    Post subject: Reply with quote
SlayerSST wrote:
Save your pennies for a 5 lug setup. $200 max.
Cheaper to maintain and better performance.
Then after that, save for some brembo calipers and turbo spindles for the extra bling.
I'd be very surprised if you could put together a 5-lug setup for less than $200. I paid closer to $800. I know this has been beaten to death in other threads, but giving people unrealistic budgets does not help. I would say plan on paying $500-$1000 for everything. The five-lug brakes are a pretty good upgrade and worth the money in my opinion, but don't start buying a bunch of stuff expecting it to be cheap. I would replace the rotors, and then spend some time researching and acquiring parts for a 5-lug conversion if you still want to.
1978 924 -parts car
1982 924 -sold
1985 944
!tom
PostPosted: Thu Jul 17, 2014 4:57 pm    Post subject: Reply with quote
Early master cylinder and brake booster combo works just fine with the 5-lug setup. You just have more pedal travel than the late master cylinder and brake booster combo. The front/rear brake bias remains the same, as both configurations have the X brake line routing and same bore in both channels.
The difference is the early master cylinder and booster requires more pedal travel for the same brake rate as the late master cylinder and booster. There is plenty of reserve travel. I assume pedal effort is similar, as the late booster increased in size to compensate for the increased bore of the late master cylinder.
I suspect the reason the master cylinder and booster was changed is that pad knock-back is more noticeable with the early setup than the late configuration, due to the fact the early bore moves less fluid for the same pedal travel as the late model. Indeed, 4-wheel disks have twice as many calipers that can knock back than the 4-lug configuration.
Both will work, late model is better in many ways (but not all; a booster failure is worse with the late setup), but the difference is small.
All just my opinion (as someone running this configuration) of course.
78 924 NA
5-lug
!tom
PostPosted: Thu Jul 17, 2014 5:05 pm    Post subject: Reply with quote
You're going to get 4 serviceable rotors, 5 wheels (gotta remember your spare), tires, pads (4 pair), calipers (4), shoes (2 pair), brake lines, front wheel bearings, seals, lug nuts, spindles, backing plates, E-brake cable, plus no doubt more things I'm forgetting all for < $200?
This doesn't include any of the while-you're-in-there servicing either, like replacing wheel bearings, seals, etc.
When is it, the 1700's?
Like others have said, I'd strongly suggest replacing the wear items, such as rebuilding the calipers, new pads (shoes are probably fine), rotors, grease seals, wheel bearings, tires, etc.
78 924 NA
5-lug
MikesCoupeGT
PostPosted: Thu Jul 17, 2014 11:10 pm    Post subject: Reply with quote
I must say I am following this thread with interest.
This is something that I am considering and will do, seeing as I track my car and want the best braking I can get.
Cheers;
MikesCoupeGT
'76 924
'83 944
''19 Elantra GT N-Line
nickthompson
PostPosted: Thu Jul 17, 2014 11:15 pm    Post subject: Reply with quote
I got a complete suspension from an 86 944 for $150. It however will need new rotors and likely need rebuilt calipers. It also didn't come with the e-brake cable. 3:-
ThomasJoseph315
Guest
PostPosted: Fri Jul 18, 2014 3:07 pm    Post subject: Reply with quote
!tom
PostPosted: Sat Jul 19, 2014 12:47 am    Post subject: Reply with quote
Don't forget wheels, tires, lug nuts, etc. from your shopping list.
Lug nut availability might need consideration outside of a run to your FLAPS, as they're a ball seat rather than the domestic cone seat.
78 924 NA
5-lug
PostPosted: Sat Jul 19, 2014 1:07 am    Post subject: Reply with quote
Not sure why you would buy hard parts new. . .PartsHeaven is right up I-5 from you.
PostPosted: Tue Sep 23, 2014 8:22 pm    Post subject: Reply with quote
I'm getting into this late, but here's my 2 cents.
Back in 1998 when finished the 5-bolt conversion to my 81 924, it cost me about $900, (including $600 for a set of phone dials, having the phone dials powdercoated, and a new set of P600s.
I serviced the brake calipers and used a lot of new parts that I shopped for over time, which made the actual conversion go much smoother at the end. I think it took me about one hour per corner to install the parts when the time came. I got all new German wheel bearings ($5 each, $10 per wheel), new German rotors (about $20 each from the old Automotion Swapmeet), rebuilt all four calipers (rebuild kits cost me about $15 each corner at the time), and got new brake pads for all four corners ($5 per axle set from the Pomona Porsche Swapmeet).
The most of the used brake parts came off a 85 944, including the calipers that I rebuilt. If you go with used parts from a 87 924S, or 85 944, you get alloy parts that were iron, or stamped sheet steel on 931s and earlier 944s. This has the advantages of much lower weight with better rigidity, and strength, and the elimination of the rust problem.
Since then, 944s have become much more plentiful in the self-service salvage yards, so the price of used parts has come down significantly.
If you choose to go with used parts, I believe you could get everything in good used condition with the exception of wheels, unless you get lucky for less than $200 in a single trip to one of the local PickAPart yards.
I ended up selling the front suspension including the struts and the rear brakes for about $50 a corner, about $200 in all, and sold the four bolt Weissach Special Edition wheels and practically new Continental tires for another $300. Which reduced the final cost of my conversion by a big chunk.
I ended up with almost two sets of extra conversion parts (sold most parts after I was finished with the conversion) since I was gathering and evaluating parts from 931s and different model year 944s before I finalized my parts selection.
Page 2 of 2
