Interesting effects from brake booster on idle speed
Raize
PostPosted: Sun Aug 10, 2014 5:37 am    Post subject: Interesting effects from brake booster on idle speed Reply with quote
I recently discovered that if I repeatedly pump the brake pedal when the engine is warm, the revs will drop significantly from the standard 1000rpm idle until I stop pumping the brake pedal.
Strangely enough, if I do this when the engine is cold, the opposite occurs and I can make the revs increase.
I suppose that the additional air being allowed into the engine via the brake booster causes the mixture to be leaner than it normally would be.
Does this mean my engine is running too rich when cold (but that's normal of course) and too lean when hot?
PostPosted: Sun Aug 10, 2014 6:13 pm    Post subject: Reply with quote
Get a wideband and a gauge to check your AFR.
PostPosted: Sun Aug 10, 2014 9:44 pm    Post subject: Reply with quote
My father would say this ....... 'stop pumping the brake pedal !!'
PostPosted: Sun Aug 10, 2014 11:45 pm    Post subject: Reply with quote
epic !!
Raize
PostPosted: Mon Aug 11, 2014 2:53 am    Post subject: Reply with quote
There is that, of course.
Does the adjustment screw on the fuel distributor actually effect the mixture at any amount of revs other than idle? I was under the impression that it's just a stop for the air plate from looking at the k-jet diagrams.
PostPosted: Mon Aug 11, 2014 3:25 am    Post subject: Reply with quote
Screw alters mixture across the board.
Ian89C4
PostPosted: Mon Aug 11, 2014 9:58 am    Post subject: Reply with quote
I would check for vacuum leaks going into the brake booster. Or your may have a leak on the back end of it (inside the car attached to the brake pedal). I would leave the fuel and air alone until you can rule out a bad booster. If you play with the AF mixture without a wideband hooked up you will never be able to get it right.
Good luck,
Ian
Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala")
PostPosted: Mon Aug 11, 2014 11:37 am    Post subject: Reply with quote
And if you play with it without running baseline fuel pressure and delivery tests you will also end up frustrated.
Ian89C4
PostPosted: Tue Aug 12, 2014 7:10 am    Post subject: Reply with quote
What he said
Ian Edgerly
North Carolina
Current:
