937 ignition challenge
Goto page Previous  1, 2
PostPosted: Mon Jul 14, 2014 6:47 am    Post subject: Reply with quote
Sorry, no alternative sensor has been found as far as I'm aware despite contact to Porsche, bosch and Siemens. Various tests on current crank sensor and no conclusive results on what signal the DITC box is looking for from the sensor, at least here in the UK. This path has been trodden dozens of times by people who need a sensor. Would love to see a solution as working ones will only become more rare
PostPosted: Mon Jul 14, 2014 7:52 am    Post subject: Reply with quote
Pic of the Mittelmotor distributor fitted on my engine can be seen on this thread http://www.924board.org/viewtopic.php?t=34690&postdays=0&postorder=asc&start=360 The black rubber bung on the front of it covers the mini USB socket for tuning advance and retard via laptop. This dizzy allowed me to run more boost without any knock compared to my stock S1 distributor. Engine runs more consistently and much smoother
peterld
PostPosted: Mon Jul 14, 2014 6:38 pm    Post subject: Reply with quote
Currently a sensor on UK ebay for a hundred and fifty quid!
80/81 932/8 ROW
Gijs937
PostPosted: Tue Jul 15, 2014 12:45 am    Post subject: Reply with quote
Thanks for the lead!!!!!!!
I contacted Paul and so far so good.
I will keep you posted...
Gijs937
PostPosted: Tue Jul 15, 2014 12:49 am    Post subject: Reply with quote
@Steve: your car looks absolutely stunning!!
Does the Mittelmotor kit comes with all the parts??
Finetuning needs BHP readings etc.. Is it standardised in the Mittelmotor kit?
Gijs937
PostPosted: Tue Jul 15, 2014 5:59 am    Post subject: Reply with quote
Bought it!! Thanks for the lead Peter..
PostPosted: Tue Jul 15, 2014 6:43 am    Post subject: Reply with quote
It's a plug and play distributor. Mittelmotor will load a starting map to get going. Further fine tuning can be done on the dyno or road via a laptop.
peterld
PostPosted: Tue Jul 15, 2014 4:53 pm    Post subject: Reply with quote
Steve......sounds awfully impressive.
What exactly is the 'starting map' like......just driveable, or OEM settings. or ? Does Mittelmotor then provide a program, or how does it work?
80/81 932/8 ROW
PostPosted: Wed Jul 16, 2014 8:02 am    Post subject: Reply with quote
Michael at Mittelmotor can provide maps to suit the car it's being fitted to. However it's still best to fine tune to your own application. I'm running the same map as their GTS race car. You can have two maps installed on the dizzy and live switched between them.
peterld
PostPosted: Wed Jul 16, 2014 9:59 am    Post subject: Reply with quote
Interesting....thanks.
80/81 932/8 ROW
Gijs937
PostPosted: Wed Jul 23, 2014 7:33 pm    Post subject: Reply with quote
Cranksensor arrived from UK.... And I do have to say: I have now the possibility to get another 3, all in range between 150 and 400 GBP (!!!)
Anyway, hope to get the car fixed this week, I will keep you posted.
Thanks again to all whom replied via forum and PM, you all were a big big help!
Gijs937
PostPosted: Fri Aug 29, 2014 1:53 am    Post subject: Reply with quote
Since yesterday the car runs! With a total rebuild ignition based on original specs...
What a beast to drive..
Next phase will be Airco repair, electric window passenger side and some other small challenges.
Again, many thanks all for the support and leads!
PostPosted: Fri Aug 29, 2014 4:53 am    Post subject: Reply with quote
Fantastic. Thanks for the update. Enjoy and make sure you post more pics
Gijs937
PostPosted: Fri Aug 29, 2014 6:40 am    Post subject: Reply with quote
PostPosted: Fri Aug 29, 2014 4:49 pm    Post subject: Reply with quote
Great stance !!
Page 2 of 2
