924 80' N/A EFI, ITB
Pumba
PostPosted: Sat Jun 14, 2014 7:02 pm    Post subject: 924 80' N/A EFI, ITB Reply with quote
Hi!
I thought I'd share some information about my project with you.
A year ago, I started a race car project... For that purpose I bought a very cheap 924 ( for about 800 Euro ) It stood for 10 years not driven, kept outside, the paintwork was ( and still is ) terrible, interior could only be thrown away, the engine took huge amounts of oil...
A couple days ago, I finished the interior and engine works, and now it looks like that:
It now has 330lbs spring with GAZ shock on the front, and the 500lbs GAZ Shocks Coil-Over on the rear. 5 lug suspension from an early 944. Full roll cage.
The engine is running on EMU, Polish alternative for MegaSquirt.
Right now I'm struggling with tuning the engine ( the car is currently quicker than a standard 924, so I think I'm on a right path ) and since it is my first attempt doing a EFI conversion, I think I may need some help from more experienced colleagues...
peterld
PostPosted: Sat Jun 14, 2014 7:48 pm    Post subject: Reply with quote
Welcome! Looks great, particularly the roll cage fitment, especially through the engine bay.
80/81 932/8 ROW
Horizonblue
PostPosted: Sun Jun 15, 2014 7:39 am    Post subject: Reply with quote
Such a nice clean engine bay is usually carburetted, thumbs up for going EFI, looks very good.
Maybe there would be a benefit if you made some kind of plenum with a hose away from the engine, to draw more cold air, instead of the individual filters.
Anyway, a very good job on that car
Euro 924, 1976
"If you can't fix it, don't break it"
/P.G. Andersen
GeorgeV
PostPosted: Sun Jun 15, 2014 10:06 pm    Post subject: Reply with quote
Welcome! You've done a nice job on that 924.
1981 932 with mods:
http://www.924board.org/viewtopic.php?t=37921
Pumba
PostPosted: Tue Jun 17, 2014 5:16 pm    Post subject: Reply with quote
Thanks.
I thought about building a plenum, but for now it will stay this way, I want to install a turbo badge panel, so there will be a bit more ventilation.
Yesterday I have adjusted the ITB's to have same amount of vacuum on each cylinder, which resulted in getting a very smooth idle and acceleration while not on WOT.
For now the most important thing is the ignition table...
I run the engine on Alpha-N algorithm with MAP based ignition.
I'll post my ignition table later today, I wonder what will experts say
PostPosted: Wed Jun 18, 2014 12:34 am    Post subject: Reply with quote
Very, very nice.
Can we have a closeup pic showing what you did with the center console?
macBdog
PostPosted: Wed Jun 18, 2014 10:53 am    Post subject: Reply with quote
Great job, very neat! Would love to see more pics pre and post build please.
1979 931 with a 350 chev
1973 911E with EFI
p-talk wrote:
I'm still convinced the word 'Porsche' makes people crazy in all kinds of ways
Shurick
PostPosted: Thu Jun 19, 2014 2:48 am    Post subject: Reply with quote
Nice and clean job!
Personally I don't think that MAP as a load factor is good enough for NA ITB ignition map. You can see atmospheric pressure in hi-load modes all the time.
I'd prefer TPS as an engine load.
WBR, Shurick
'86 924S -- R.I.P.
https://www.instagram.com/ru_pacecar/
Pumba
PostPosted: Thu Jun 19, 2014 8:29 am    Post subject: Reply with quote
Thanks again.
I will switch to pure alpha-n, when I finally get a 'longer' camshaft.
For now I have very fine readings from MAP.
A bit of the history, by request:
When bought... The interior was fully 'customized' by the previous owner. Destroyed would probably be a better word though...
But, the exterior luckily looked still like a 924.
Soon, we found out how the car looked years ago, such a shame to destroy the black-white pasha interior...
3 days after purchasing, the interior was stripped and cleaned:
After that, we started to work on the engine... The head was refurbished, all seals went new, but the bottom was untouched ( which later appeared to be a mistake ). We were in hurry to finish the car before the biggest gathering of Transaxles in Poland, also a TrackDay...
Then, the 5-lug suspension went in ( did some painting of the chassis to, because the amount of putty on the sides was huge and it finally fell of creating quite nasty holes... )
Riddiculously high the car was back then... But not for long!
The GAZ setup for the rear axle arrived!
The front setup arrived about a week before the TrackDay, but were worth waiting for. Front suspension setup was built by our master-magician, mechanic from Warsaw.
It started to look bad-ass...
With the hard suspension setup, standard seats were no longer an option, so i borrowed a nicer one from my friend...
Then, just a day before the party began, I got the Michelin slicks...
And the car did great (That's the co-owner and co-creator by the wheel) :
We had some technical issues ( also called 'drivers impotence' ), which prevented us from racing for the podium, but still, the car was great...
And that ended the 2013 season... 2014 season works... soon
PostPosted: Sat Jun 21, 2014 12:40 am    Post subject: Reply with quote
wow two toofahs on the same track!
markrnorton
PostPosted: Tue Jul 08, 2014 9:17 pm    Post subject: Reply with quote
Hi, what throttle bodies did you use ?
PostPosted: Tue Jul 08, 2014 9:46 pm    Post subject: Reply with quote
Very nice !
I'll try to join the next year's meet..looks fun !
PostPosted: Wed Jul 09, 2014 1:28 am    Post subject: Reply with quote
Door cards A+
Mars478
PostPosted: Wed Jul 09, 2014 2:58 am    Post subject: Reply with quote
Looks great! Good job
924, 82, 5 speed, dark red, 500 dollar special.
Daily: 99 ML320, 210k and still trucking.
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger
Pumba
PostPosted: Wed Jul 09, 2014 9:40 pm    Post subject: Reply with quote
The ITB's are GSX-R 600 ( I think K2 or K3 model - the later ones have different design and they cannot be separated individually )
Morghen, you are welcome. It seems that this year there will be no official season-end meeting in Czestochowa, but I'm forcing an idea of a season-end Track Day in Koszalin on 12-14.09.
The door cards are made of 2mm HIPS.
Right now I'm trying to set up a plan for head modifications. Bigger Valves, longer camshaft, solid lifters... Probably I'll have to shave the block off to rise the CR. Right now I'm waiting for a reply from CatCams.
After the head is finished I plan to dyno it.
Lately I drove a friend-of-mines 944T running on 1bar boost... I think finally I will go turbo way too, but first I'll try to put maximum from the 'ole N/A.
