sitting 924S help please
dash16
PostPosted: Fri Jun 27, 2014 12:58 pm    Post subject: sitting 924S help please Reply with quote
Hello board,
my 924S has been sitting for about a year and a half while I was away and I just tried to start it. It cranked a few weak cranks and then stopped cranking, seemingly stuck.
I'm really concerned the timing belt had slipped, but there is no way I know to tell as I cannot turn the engine by hand either to see if the timing marks align.
Please advise how I can move forward with this. I trust the brilliant solutions this board can come up with! Thank you
1987 Porsche 924S Black/Black. 5-spd.
Options: AFX C79 261 398 423 650 651 657
1987 Mercedes 190E 2.3-16 Cosworth Pearl Black/Black. 5-spd.
STUTTGART PREVAILS
PostPosted: Sat Jun 28, 2014 1:46 am    Post subject: Reply with quote
what is the history of the timing belt?
dash16
PostPosted: Sat Jun 28, 2014 11:21 am    Post subject: Reply with quote
I replaced it with a Gates Kevlar belt around 10K ago. Tensioned it legit myself
STUTTGART PREVAILS
PostPosted: Sat Jun 28, 2014 12:25 pm    Post subject: Reply with quote
Have you tried to turn the motor a few degrees backwards? Starter may be jammed.
dash16
PostPosted: Sat Jun 28, 2014 5:14 pm    Post subject: Reply with quote
tried to turn it backwards and forwards. no budge. how would i go about unjamming the starter?
STUTTGART PREVAILS
PostPosted: Sun Jun 29, 2014 12:34 am    Post subject: Reply with quote
Remove the starter, check to see if it the bendix is jammed on the ring gear.
Pull the belt covers and check condition.
Check clutch operation.
Clean area near each spark plug of all debris
Pull plugs, squirt some clean oil into each cylinder, leave plugs out.
Put car in neutral
Turn crankshaft at front pulley with a long breaker bar.
Bent valves should not keep the motor from turning backwards a few degrees.
mehall
PostPosted: Fri May 22, 2015 5:12 pm    Post subject: Reply with quote
Have you checked the battery? 18 months will often kill even a new battery.
...unles you a trickle charger.
Mark
'87 White 924s manual
'94 Lexus LS400
www.kcws.org
