Dutch924-racer
Joined: 23 Jul 2007 Posts: 1081 Location: The Netherlands
Posted: Sat Feb 18, 2012 2:30 am Post subject: Wur difference for 931 ? |
Pets (EU version) shows two wurs for the M31.03. (931 series 2)
931 606 105 00 (0 438 140 062 ?)
931 606 107 00 (0 438 140 091 ?)
What is the difference and can anybody confirm the Bosch partnumbers ? _________________ 937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
Forge recirculation valve + boost controller |
ptheskil
Posted: Sat Feb 18, 2012 7:17 am Post subject: |
I believe that the ...107 part was a later introduction during S2 manufacture and therefore as an OEM part was only fitted to M31.03 engines. This part has a higher cold control pressure so not quite so much cold enrichment as the WUR fitted to the S1 engine. I seem to remember that the S2 part was withdrawn at some point and that for service the S1 part was approved for fitment to the S2 engine. The result would be a slightly richer mixture at cold start which should help initial firing at the cost of potentially more fuel in your oil and some bore washing. I guess that as Porsche approved the part for service it can't be that bad.
I can't remember where I read this so I can't quote the original source I'm afraid. Either way, as PET5 lists both parts then I would think it was pretty safe to use either.
I have a spare WUR awaiting rebuild which was removed from an original ROW S2 so I'll check the p/n's on that and let you know. _________________ 1981 931 series2 Euro spec |
Dutch924-racer
Posted: Tue Feb 21, 2012 2:38 am Post subject: |
I got two wurs, one with 0438140062 and the other 0438140113, that came from the tuned Willebald racing engine.
Which one will be the best option for a series 2 931 ? _________________ 937 trackday car
Series 2 engine
Fast road camshaft
Last edited by Dutch924-racer on Tue Feb 21, 2012 3:38 am; edited 1 time in total |
Dutch924-racer
double post _________________ 937 trackday car
Series 2 engine
Fast road camshaft
Last edited by Dutch924-racer on Tue Feb 21, 2012 3:39 am; edited 1 time in total |
ptheskil
Posted: Tue Feb 21, 2012 3:28 am Post subject: |
Here's a pic of the WUR I took off my stock '81 S2 932. As far as I know this was the factory fitted item - there was certainly 30 year's worth of oily tar behind the manifold pressure diaphragm. Bosch p/n is 0 438 140 062.
[img]https://picasaweb.google.com/lh/photo/uC6tR84NwVwWCLTydL6AadMTjNZETYmyPJy0liipFm0?feat=directlink[/img] _________________ 1981 931 series2 Euro spec |
ptheskil
techfx
Joined: 11 Feb 2014 Posts: 25 Location: Pittsburgh, PA
Posted: Tue Jun 24, 2014 2:32 am Post subject: |
I ordered a 924 T part number 9316061050 and was sent a Python remanufactured/ Bosch 0438140011 which seems to be designated for a 924 NA. Could this possibly work or not at all? _________________ 81' 924 Turbo, 02 Golf TDi, 88 Scirocco 16v (RIP)... and the Subaru. |
Posted: Tue Jun 24, 2014 3:25 am Post subject: |
Not sure on the part, but a difference between the n/a and turbo, the turbo has vacuum nipple attached to it. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
techfx
Posted: Thu Jun 26, 2014 3:09 am Post subject: |
I determined with the supplier that they did send the wrong part. Going to check out other places for a Bosch 091 _________________ 81' 924 Turbo, 02 Golf TDi, 88 Scirocco 16v (RIP)... and the Subaru. |
Posted: Thu Jun 26, 2014 3:41 am Post subject: |
Some cross-reference material on this page:
http://www.specialtauto.com/porsche-parts/index.html
And, according to this PDF, the 113 part is a VW/Audi part, although it doesn't specify what models. _________________ erstwhile owner of just about every 924 variant ever made |
Kenodog
Posted: Mon Jun 30, 2014 1:58 am Post subject: |
As it specifies on the Special T page, an -062 is for the 79-80 931 and a -091 is for an 81-82. _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
