First Porsche, 81 924T not revving past 3K RPMs
techfx
PostPosted: Tue Feb 11, 2014 9:59 am    Post subject: First Porsche, 81 924T not revving past 3K RPMs Reply with quote
Hello,
This is my first Porsche (former VW Scirocco owner for 14 yrs).
I purchased a 1981 924 Turbo over a week ago and I knew it had some tinkering done by previous owners and mechanics. It is low mileage, but currently has an issue where the engine cuts out right at 3k RPMs while driving (not while revving in neutral, however).
Things I know that may be factors at this point (but not sure where to start):
*Mechanic replaced the ignition distributor w/ an older (pre 80?) one that does not use the crank sensor
*Has what appears to be Bosh number 0438100058 (Saab?) Fuel Distributor
*Sensor missing wire going in intake that passes over valve cover
* Vacuum line T by the head light motor appears to have a line capped off.
*Fuel may have been in the tank for over a year (I did put on about 5 gal of 93 octane last week).
I'll have time to look at things more when the weather improves here, but would like to get as much info as possible when the chance comes. The rest of the car seems close to passing PA inspection.
thanks!
PostPosted: Tue Feb 11, 2014 12:00 pm    Post subject: Reply with quote
The non-DITC ignition distributor is not a good sign. The car might be running, but will never run correctly unless you get the correct distributor, or retrograde from the DITC setup to the earlier capacitve discharge arrangement.
In the meantime, here is A Systematic Approach to 931 Diagnostics.
Do you have a Haynes manual yet? Do you have a (digital) copy of the Factory Service Manual (FSM)?
techfx
PostPosted: Tue Feb 11, 2014 1:22 pm    Post subject: Reply with quote
The mechanic (who was a previous owner before the guy I bought of off) stated he switched it to the earlier full arrangement and it did run fine from that set up for a while (while he owned the car).
My Haynes manual is in the mail.
PostPosted: Tue Feb 11, 2014 4:15 pm    Post subject: Reply with quote
Assess condition of timing belt.
READ THIS.
Smoke test intake, check system and control fuel pressures, fuel pump volume.
techfx
PostPosted: Wed Feb 12, 2014 10:11 am    Post subject: Reply with quote
Thanks for all of the helpful hints and sites to follow up on! Lots to take a look at, it looks like. I'm also assuming that having the Saab fuel distributor wouldn't be an obvious issue since no one mentioned it?
PostPosted: Wed Feb 12, 2014 10:26 am    Post subject: Reply with quote
The Saab fuel dizzy is not a good sign either. The WUR, AFM, Fuel Distributor, and AAV are all a matched set in order to deliver the proper fuel curve.
The first thing we need to isolate is what is cutting out at 3000 RPM: fuel or spark. Since you state that it will rev past 3000 in neutral, I am inclined to believe it's not a spark/ignition issue. If I were in your shoes, I would start with CIS testing. Here is a tutorial:
http://www.924board.org/viewtopic.php?t=35734
First, you should verify proper injector flow. Remove all four injectors. Put them in individual glass jars. Jumper the fuel pump relay. Press on the AFM plate. Make sure you're getting a good conical spray pattern across all four injectors, and make sure they all deliver roughly the same volume of fuel (no dribblers, and no gushers). This will help you diagnose whether the fuel dizzy is at least in the ballpark of proper functioning. It will also tell you something about your fuel pumps (which may not be delivering enough fuel under load).
Once you've eliminated the injectors, fuel dizzy, and fuel pump as the possible culprits, proceed with the full battery of CIS tests. You will need the Haynes manual to provide the correct pressures for the S2 car (chapter 13 supplement). You will need a proper CIS testing unit in order to measure the pressures as described in the above tutorial. Following the diagnostics in the tutorial thread, this will tell you which if any of the CIS components might be a problem (WUR being the most likely).
techfx
PostPosted: Thu Feb 13, 2014 3:54 am    Post subject: Reply with quote
I may actually start with replacing the dizzy, then (sorta familiar w/ the term from VW boards). The mechanic I spoke with told me it has new fuel pumps and new injectors (he gave me the old injectors). I will do the other fuel sys testing after having the correct part in. I see the dizzy is difficult to find/expensive, but I want to work towards making sure all of the parts used are correct.
techfx
PostPosted: Wed Mar 19, 2014 8:55 am    Post subject: Reply with quote
I have a supposed tested/used correct 924T fuel dizzy to install, but cannot find a 93111013701 Paper gasket for the fuel/air box and 93111090800 o-ring for the bottom of the dizzy. I could possibly make/repair the paper gasket, but am wondering if the O-ring would be a generic size that could be ordered elsewhere.
techfx
PostPosted: Tue Apr 15, 2014 7:47 am    Post subject: Reply with quote
I now have the proper Dizzy in place, have an approximate mixture adjustment as best possible without a CO2 meter (it didn't idle at all after switching from the Saab part, before this adjustment ). It seemed like it had a little more power, but still continues cutting out at 3-4k rpms now.
I also just found that one of the stated "new" vacuum lines going to the conical end of the distributor had a crack. I ran out of time at this point for the week, but will replace the vacuum lines. I also found that this line also had a T fitting where one other part of the line (that seemingly was run under the WUR) didn't appear to be connected to anything and was very short. I'm not sure where this goes and I think the other end of the T fitting goes to the throttle body
Since this was a DITC to S1 ignition "downgrade", I'm not quite sure what vacuum diagram to go by and if there may be possible missing needed vacuum parts (ie Vacuum amplifier)?
techfx
PostPosted: Tue May 06, 2014 6:49 am    Post subject: Reply with quote
Update after a few weeks:
Replaced all of the oem/new looking cracked cloth vacuum lines and undersized T fittings with silicone lines, gutted the Prosport boost controller to remove some restriction there, replaced all plugs and wires. I also noticed the thremo vacuum valve is not connected, but I also don't see it in the 1980 Distributor/Vacuum diagram. Checked compression on all cylinders which were about 135-150psi. It still seems to run a bit rough, but now my hesitation is only starting off from idle attempting to drive the car and no longer any issue in higher RPMs. Guess I'm getting a bit closer... May try making timing marks to adjust ignition timing and readjusting the fuel mixture again next weekend.
PostPosted: Tue May 06, 2014 6:53 am    Post subject: Reply with quote
It wouldn't hurt to run a bottle of Techron fuel system cleaner in each of your next two fillups. That stuff does wonders for the fuel system.
Wiese
PostPosted: Thu May 08, 2014 9:06 am    Post subject: Reply with quote
Check the ignition coil with an Ohm meter. My 931 had similar issues as yours and my primary resistance on the coil was way too low. It revved freely, but hesitated under load and would sputter. A $45 coil was the fix, but my 931 was otherwise in excellent tune already.
techfx
PostPosted: Mon Jun 09, 2014 6:10 am    Post subject: Reply with quote
Here's where I am after a few weeks since the last update. I managed to get the car past PA state inspection, but still has a misfire. It looks like plug #2 always has some fuel/oil residue. I pulled the injector to test and, while cranking the engine (ignition disabled) I saw one quick spray and then nothing after. we tried w/ the injector off of the line and no fuel even dripped out until I pushed down on the air/fuel metering plate, pulled the line off and it can be blown through. It was decided to finally do the CIS fuel system checks.
This weekend, i found a CIS pressure tester and was going to attempt to jump the fuel pump relay to run the pump, but my fuse box does not look like any diagrams. The top row has one relay on the far left, then a gap, then the others. The gap is seemingly where the fuel pump relay would have been. I found the relay on the far left had a part number of 944-613-113-00 which looks like the stock fuel pump relay number, other than starting with 944 instead of 931. I tried to jumper 87 and 30 on that relay, but no pump would run. We decided to try to measure system pressure while cranking, and got 4.1 bar, the control pressure was 3.8 bar. These do not seem to be within the proper range, but I'm not sure running the fuel pump while cranking is an acceptable way to measure fuel pressure
One other thing; I'm waiting for a new fuel filter and I noticed when researching part numbers that the current Mann WK 726 part on the car seems to match for a 928 on some sites, but not 924 Turbo. I will try to switch out with the correct fuel filter next weekend, but not sure if that is what could be the cause of the possible pressure issue.
81' 924 Turbo, 02 Golf TDi, 88 Scirocco 16v (RIP)... and the Subaru.
techfx
PostPosted: Mon Jun 09, 2014 7:05 am    Post subject: Reply with quote
Actually had a break in the weather and got to go back an find the proper fuel pump relay (2 over to the right from where I tested), found the correct part number and jumpered that 87 to 30. This time got sys pressure of 5.5 bar and control of 4.5 (this is also cold, but it is 74 deg ). Still seems low system and high for control?
also, after approx 14 min, I was at 1.6 bar.
techfx
PostPosted: Tue Jun 17, 2014 4:11 am    Post subject: Reply with quote
This weekend was a little bit more of a nightmare.
I replaced fuel filter , did another fuel pressure reading, sys pressure reading of 5.5 bar, cold control 4.7 bar (still seems high?) My Dad suggested checking timing, looked like Cam was off by one tooth and distributor by 180 degrees. I tore everything down and got everything lined up as Hayes described and it still runs the same . Could there still be an issue like blockage in he distrubutor/WUR?
