Fuse Issue in my 82 924
jhattie
PostPosted: Tue Jun 03, 2014 11:22 pm    Post subject: Fuse Issue in my 82 924 Reply with quote
Anyone ever have this?
I keep blowing the fuse in #7 on the main box, the radio/interior lights. I have NO radio installed at all and all lights removed yet it pops every time.
04 Avant Ultra Sport Wagon 1.8T
07 Rabbit
lot of Jetta's
PostPosted: Tue Jun 03, 2014 11:41 pm    Post subject: Reply with quote
Probably a wire that used to go to the radio is improperly terminated, so it's probably shorting to chassis/ground.
Why put in a fuse on a circuit that isn't needed?
78 924 NA
5-lug
jhattie
PostPosted: Tue Jun 03, 2014 11:56 pm    Post subject: Reply with quote
it also controls the dome and glove box lights
07 Rabbit
lot of Jetta's
PostPosted: Wed Jun 04, 2014 4:08 am    Post subject: Reply with quote
yeah make sure the main and aux power for your radio aren't just dangling around back there shorting on something...
power antenna wires in my car come from there too so if you have that fuseable link open it may be shorting too...
dome and glovebox lights are easy to pull out, make sure there contacts aren't bent together or touching anything conductive other than what there supposed to touch..
80 Turbo - Slightly Modified
jhattie
PostPosted: Thu Jun 05, 2014 12:01 am    Post subject: Reply with quote
Found it!!! was the light in the hatch, it was grounding off the body.. Now to find the rest of the Gremlins
07 Rabbit
lot of Jetta's
