FFNPMcD
Joined: 15 Aug 2013 Posts: 19 Location: Richmond, Va.
Posted: Wed May 14, 2014 6:47 am Post subject: 87 924s oil capacity and recommended weight/brands |
About to do an oil change in a 87 924s I picked up. Im not to sure what was used previously for oil and car didn't come with an owners manual.
Can anyone tell me what the capacity is?
What weights and brands are you using?
Synthetic or non..
Thanks,
Neill _________________ 1987 924s |
FFNPMcD
Posted: Wed May 14, 2014 6:59 am Post subject: |
Thanks for such a quick reply! _________________ 1987 924s |
Posted: Wed May 14, 2014 7:57 am Post subject: |
There are a million threads out there on oil preferences. See the Pelican 911 forum for example, lots of name-calling there~~! Some say synthetics are the way to go (prolly not available when car was new?), or others say VR1 20-50 or Brad Penn 20-50, or other dino-based oil. Here is an example of said discussion:
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/751482-ok-1st-oil-change-nice-please-lol.html _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Wed May 14, 2014 1:42 pm Post subject: |
If you do not know what type of oil was being used, use dino. I use 10W-40 Pennzoil. _________________ White 87 924S "Ghost"
pmcaya2
Joined: 24 Nov 2005 Posts: 191 Location: Scio, NY USA
Posted: Wed May 14, 2014 2:18 pm Post subject: |
There was some consensus for heavier 20-50W oil in a thread I posted - better oil pressure in an older engine.
Re: capacity - (old school) replace the filter and add around 4 1/2 quarts. Run the car around, check for leaks, then top off if necessary. Some engines can use 1qt over 1000 miles without smoking or leaking, so check it periodically.
Caution: This car can piss oil further and faster than any car ever made. Place the drain pan far behind to drain plug, then move it another 3 inches! |
Posted: Thu May 15, 2014 1:38 am Post subject: |
20w50 is ABSOLUTELY NOT the recommended weight. Porsche changed this a few years ago to 0w40 synthetic.
Not willing to go to 0 myself, so I run LiquiMoly 5w40. _________________ Toofah King Bad
pmcaya2
Posted: Thu May 15, 2014 11:55 am Post subject: |
If Porsche recommended 0-40W it must have been for current cars (although zero viscosity is impossible).
5W-30W is recommended for my modern Toyota and similar cars because the clearances in modern cars are tighter than older vehicles.
A mechanic put 5W-30 in my '82 924 and I found that oil pressure was slightly less than 2 bar (30psi) on idle on a hot day - and the oil light would come on. Had an extensive thread on this issue and consensus was 20-50W for summer driving. I use paraffin based Pennsylvania oil and the car has 185 K miles.
PS I don't want to start an "oil wars" thread, so I'll sign-off with this post. |
Posted: Thu May 15, 2014 1:20 pm Post subject: |
| pmcaya2 wrote: | | If Porsche recommended 0-40W it must have been for current cars |
So wrong. LOVE oil threads!
Porsche TSB is for "all production sports cars."
Yes, this applies to your 356. _________________ Toofah King Bad
Mars478
Posted: Thu May 15, 2014 1:26 pm Post subject: |
I run 0W-40 in my 1999 ML320, Mobil 1 Euro formula. For the 944 engine, I have found 20W-50 be the recommended grade, but it was from research from posts a long time ago. It would be great if 0W-40 was the recommended grade because I can get that super cheap from Wal-Mart. Maybe if you could post the TSB that would help? _________________ 924, 82, 5 speed, dark red, 500 dollar special.
Daily: 99 ML320, 210k and still trucking. |
Posted: Thu May 15, 2014 3:38 pm Post subject: |
Porsche TSB, 4 Sept 2009. Image from Alldata:
Mars478
Posted: Fri May 16, 2014 3:24 am Post subject: |
| Rasta Monsta wrote: | Porsche TSB, 4 Sept 2009. Image from Alldata:
Do you think that applies to the past cars? Has anything changed that makes 0W-40 the recommended grade of oil? _________________ 924, 82, 5 speed, dark red, 500 dollar special.
tyfighter123
pmcaya2
Posted: Fri May 16, 2014 1:43 pm Post subject: |
20W-50 is the correct answer.
From tyfighter123's link " the low viscosity of a 0W-30 oil means optimum cold-start behaviour, low engine resistance and other benefits in modern engines. In a 356, however, an oil of this kind can result in leaks and increased oil consumption due to the engine's higher production tolerances and lower oil pressure during operation."
An 80's engine was built to lower tolerances and requires a higher viscosity oil for thing's like oil pressure (see my previous posts). And high mileage engines more so .....
Now the 924 engines are extremely durable and you can probably get away with piss-thin oils, but as Clint would say, "Do you feel lucky?" |
FFNPMcD
Posted: Fri May 16, 2014 9:12 pm Post subject: |
Thanks for all answers, sadly I jumped the gun before the post got good and used the Mobil 1 Euro formula (0W-40).
Little worried now so I'll be sure to keep an eye on consumption and gauge.
I use to car to get me to the firehouse in the mornings so I'm only driving about 700 miles a month. (plus a few fun miles).
I don't see this vehicle on a track any time soon.
Thanks for all the responses guys. Didn't want to start oil war, I honestly had no idea without the manual. _________________ 1987 924s |
