kirkvw72
Joined: 09 Apr 2014 Posts: 5 Location: Bartlett, Illinois
Posted: Wed May 14, 2014 1:00 am Post subject: |
Ideola Dan has those. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Power Tryp
Joined: 16 Apr 2009 Posts: 435 Location: Calgary, Alberta
Posted: Wed May 14, 2014 1:44 am Post subject: |
I'll narrow this down a little bit for you http://garage.ideola.com/prod-BoostSolutions.html#931 that's the direct link. _________________ Melanie - 1980 931
NoName - 1980 931 (seeking rebuild)
Green tartan interior, you don't see that on a Civic. |
9xx
Posted: Wed May 14, 2014 2:43 am Post subject: |
#18 is possibly included in a 944 2.5 N/A oil cooler repair kit. This is just information for everyone in a case of a emergency, if it happens you can't find one anywhere. I'm not 100% sure of this but few years ago I remember when I tried to find the proper green O-ring but it was NLA. Then finally got it from somewhere abroad and after it was installed I came across this partially used 944 oil cooler repair kit in my garage... and there it was! The same green O-ring.
So in case you can't find one, check the 944 repair kit.
edit: So this is not 100 % accurate information but then again could be. Beware and check before buying anything. _________________ Mikko
Posted: Wed May 14, 2014 8:01 am Post subject: |
9xx, are you talking about the upper green viton o-ring, or the lower, black o-ring? Big difference in the two, besides size, high pressure on top and low pressure on the return line. _________________ '83 944 Track car.
9xx
Posted: Wed May 14, 2014 4:37 pm Post subject: |
| Grenadiers wrote: | | 9xx, are you talking about the upper green viton o-ring, or the lower, black o-ring? |
Perhaps I was talking about the upper green O-ring. Can't remember anymore (I'll get me coat) _________________ Mikko
kirkvw72
Posted: Tue May 20, 2014 8:58 am Post subject: Thanks! |
Thanks everyone! Ideola's garage kit was the perfect solution for me. Know I have to decide if I want to send the turbo off for a rebuild.  _________________ 1981 931
1987 951
1987 Vanagon GL
1972 VW Beetle
1992 Miata
2013 Touareg Lux Vr6 |
