ThomasJoseph315 Guest
Posted: Sun May 04, 2014 2:31 pm Post subject: Brake master rebuild |
Is there any info on rebuilding the Brake Master Cylinder? I never done this before on any car.
Thanks. |
SlayerSST
Posted: Sun May 04, 2014 5:17 pm Post subject: |
Why not get one from Autozone or O'Reilly with lifetime warranty?
I recommend that you do get one with lifetime warranty because these cylinders rust really fast.
Cheaper in the long run. |
Posted: Sun May 04, 2014 9:57 pm Post subject: |
| They want $100 and a rebuild kit is $12 |
Posted: Mon May 05, 2014 3:15 am Post subject: |
The instructions in the kit should be good enough.
Replace the seals. Make sure you understand how it fits together / comes apart (including the bolt that provides a travel stop for the intermediate piston).
Bench bleed thoroughly. _________________ 78 924 NA
5-lug |
Posted: Mon May 05, 2014 4:17 am Post subject: |
where is this kit for $12?
I need to do mine too. _________________ 80 Turbo - Slightly Modified |
larchie
Posted: Mon May 05, 2014 6:46 am Post subject: |
The 4-lug: RockAuto
Major repair kit with seals, washers, clips, US$30
Minor repair kit with pistons US$12 |
pmcaya2
Joined: 24 Nov 2005 Posts: 191 Location: Scio, NY USA
Posted: Wed May 07, 2014 3:10 pm Post subject: |
For what it's worth, I tried rebuilding my master cylinder and it just didn't work.
I swear that I did everything per instructions, but recall that there are some unique seals involved. I ended up buying one for around $80.
Considering the work to remove the MC, prime it, and bleed the brakes, (and the nasty nature of brake fluid), I'd recommend buying a new MC - if there is a problem, then you can vent at someone other than yourself.
And you probably never have to do it again over the life of the car. |
Posted: Sat Jun 07, 2014 1:38 am Post subject: |
I finally ordered the replacement seals today. If anyone can find a video on the internet I would love to see it. If no one can find one by the time it gets here, I'll make one . I've tried searching you tube so far, no results. But maybe I am not entering the right info. |
Posted: Wed Jun 11, 2014 6:14 am Post subject: |
Part #: Beck Arnley 071-7673
Success!
For the most part, it was pretty straight forward. I actually found the details of rebuilding the master cylinder in the Hayes manual, lol. However, the tricky parts that it didn't cover is something that people might wanna know about. The repair kit was actually updated and there is this plastic washer that was eliminated from the parts and for good reason. The plunger didn't come out right away and needless to say it had to be pried out. I had to take a pair of vice grips on the shaft and pry between that and the housing to get the plunger out. After that it was pretty strait forward. Just lay your pieces out as you remove them and assemble in reverse order.
Heads up,.. you do not need to remove the reservoir or the pressure sensors for this. There is a pin that screws in between the reservoir inlets, but there is plenty of room to get it out.
No more brake fade, yay!
Pic for those who wanna see the fun
