Martin_924er
Joined: 24 Nov 2010 Posts: 6 Location: Derbyshire, UK
Posted: Thu Apr 24, 2014 1:41 am Post subject: RHD NA power steering help |
hi, in need of a bit of help.
im installing power stewing on my UK R/H/D 924na
I've got the adaptor plates from Ideola's garage but i need to know which power steering rack i need and part numbers if possible. I've think I've got all the other parts needed. just need the rack.
many thanks,
Martin _________________ Black 1985 924 lux |
Posted: Thu Apr 24, 2014 5:25 am Post subject: |
Someone here in the UK fitted power steering I believe https://porsche924.co.uk/forum/index.php just can't remember who/when!? _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
GeorgeV
Joined: 14 Mar 2010 Posts: 306 Location: Brisbane, Australia
Posted: Thu Apr 24, 2014 10:59 pm Post subject: Re: RHD NA power steering help |
| Martin_924er wrote: |
I'm doing this also. My research says you'll need a 944 power steering rack. All 944s used the same power rack. PN 945 347 011 22. You'll also need the tie rods 944 347 033 20, and the drive shaft 945 347 027 00. http://jmgarage.com/ sell a better than stock drive shaft. These are all RHD PNs.
Are you using a 944 power steering pump? _________________ 1981 932 with mods:
http://www.924board.org/viewtopic.php?t=37921 |
Martin_924er
Posted: Fri Apr 25, 2014 4:51 am Post subject: |
cool thanks, I'm not using a 924 pump, I'm going to try and use a electronic power steering pump from a clio _________________ Black 1985 924 lux |
GeorgeV
Posted: Sun Apr 27, 2014 8:43 pm Post subject: |
I also plan to use an electric pump. What made you choose a Clio pump? Do you think a Ford Focus pump would work? _________________ 1981 932 with mods:
