Fog lights for a non euro bumper
pw49
PostPosted: Sat Mar 15, 2014 1:02 pm    Post subject: Fog lights for a non euro bumper Reply with quote
Has any one tried installing fog lights into a non euro bumper that only has cut outs for turn signals on a 1988 924s Porsche. Any comment will be appreciated.
pw
PostPosted: Mon Mar 17, 2014 9:27 am    Post subject: Reply with quote
US 924 and 924S have holes drilled on the bottom of the bumpers for mounting foglights.
Euro bumpers are completely different parts with holes formed in the bumper to fit the foglights. cutting the same holes in US spec aluminum bumpers would be an EPIC Adventure.
I'd recommend using the existing under bumper holes to add foglights to a US car.
Why reinvent the wheel?
jason c
PostPosted: Mon Mar 17, 2014 10:25 am    Post subject: Reply with quote
I was actually just thinking about this myself. First, you'll have to permanently remove the bumper pads. Then you'll have to cut the holes for the fog lights, cut some aluminum to make a "box" or "frame" to hold the light and the weld it in. Are you planning on using factory lights or aftermarket ones? How good are you at welding and fabrication?
kcoyle
PostPosted: Mon Mar 17, 2014 11:52 am    Post subject: Reply with quote
"smoothie" on this board has done it. Check the thread below.
http://924board.org/viewtopic.php?t=28903&sid=6d8d3511d09b60304598a14f191dd007
PostPosted: Tue Mar 18, 2014 8:11 am    Post subject: Reply with quote
I've done it... I completely reworked a us bumper it now has the euro look.
Power Tryp
PostPosted: Wed Mar 19, 2014 1:08 pm    Post subject: Reply with quote
Something you may want to consider as it's something I've been thinking about would be installing a couple of these guys. http://www.rigidindustries.com/led-lighting/21211
Kinda spendy yes, but there's no need to fab up any mounts and they won't put much if any strain on your electrical system.
Melanie - 1980 931
NoName - 1980 931 (seeking rebuild)
Green tartan interior, you don't see that on a Civic.
PostPosted: Thu Mar 20, 2014 8:29 am    Post subject: Reply with quote
Those will do.
