'87 924 S clutch throw-out-bearing noise
TajMan
PostPosted: Wed Feb 05, 2014 4:34 am    Post subject: '87 924 S clutch throw-out-bearing noise Reply with quote
My '87 924 S's clutch release bearing always made noise when I pressed the pedal ever since I bought it, but it wasn't bad and never got worse.
I just did the headgasket and timing belt, and now the noise is much louder when I push in the clutch pedal! I'm surprised it got so much worse from just sitting 6 months or abouts.
RockAuto has a Timken release bearing #614132 for $120
Is that part any good, and I suppose the cheapest way to fix my problem?
When I have the clutch all apart, I would take in the disc itself to a local clutch shop I use who will rebuild it like stock for cheap, that way I have a new disc and a new TOB that should keep lasting.
How many hours am i looking at to do a clutch job? Am I right in remembering, removing the rear transmission mounts to drop the trans and the whole torque tube lower will give me enough room to get to the clutch?
'87 924 S
PostPosted: Wed Feb 05, 2014 4:37 am    Post subject: Reply with quote
The 924S is the same as an early 944:
http://www.clarks-garage.com/shop-manual/clutch-01.htm
So about 16 hours and I'd replace get a new clutch kit so that you don't have to do it more than once. Don't forget the pilot bearing as well.
PostPosted: Wed Feb 05, 2014 5:55 am    Post subject: Reply with quote
Others have successfully used spray lube to quiet an ornery TOB. Do a search. Also, follow clutch inspection procedure from Clark's for long term planning purposes.
TajMan
PostPosted: Thu Feb 06, 2014 2:20 am    Post subject: Reply with quote
I'm not 'doing it more than once' I am selling the car, just trying to get it into normal operating range first.
I'll search about TOB lubrication, thx
what a nightmare, it never ends,
my custom exhaust, which I just spent much time fixing, is all one piece and can not be removed from the vehicle without cutting it in half,
FML
'87 924 S
PostPosted: Thu Feb 06, 2014 2:50 am    Post subject: Reply with quote
Why would you do a custom exhaust for a 924S when you could have just ordered one for a 944?
Or if you had to do a custom exhaust, why wouldn't you put in some removable sections? Since you know that is usually the first step in many of the maintenance items under the car.
Just the cut the pipe in a couple of spots where it is straight and put some of these clamps on it:
http://www.summitracing.com/parts/wlk-33222?seid=srese1&gclid=CIrViPu5tbwCFSFo7AodNyMAhw
TajMan
PostPosted: Thu Feb 06, 2014 3:26 am    Post subject: Reply with quote
I didn't do it, I bought the car that way it already had a 3" exhaust!
I added a cat converter, and I fixed a section in the rear that went over the rear axle and rubbed a hole through the pipe when suspension was fully compressed! But it never had any flanges it was already one-piece, and I didn't add any myself.
I wonder if that exhaust coupler would make a good seal all the way around? maybe
my other option is to weld two flanges on where I cut the pipe in half for a regular gasket in-between.
'87 924 S
PostPosted: Thu Feb 06, 2014 3:46 am    Post subject: Reply with quote
3" exhaust? What the.... Some people
Yeah, some 3-bolt flanges would work, but would be a bit harder to install since you have to get the clocking correct.
However, those clamps do a good job of sealing provided the pipe is fairly round and clean and it can be done fairly quickly.
edredas
PostPosted: Thu Feb 06, 2014 3:54 am    Post subject: Reply with quote
I realize that you're selling the car, but I would try to get stock exhaust. That 3" is way too big for the N/A and bigger isn't better. You can lose a lot of hp with the wrong pipe.
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver
PostPosted: Thu Feb 06, 2014 3:58 am    Post subject: Reply with quote
Or even a Bursch or other established aftermarket exhaust. Though some less informed buyers may see it as a bonus. It could go either way really.
edredas
PostPosted: Thu Feb 06, 2014 4:05 am    Post subject: Reply with quote
I was thinking, he could probably pick up a used one off a junker for $50 if he didn't want to put much money into it. I agree that some might think it's a bonus, but it's would probably be a day and night improvement, and definitely worth fixing, IMO.
PostPosted: Thu Feb 06, 2014 4:50 am    Post subject: Reply with quote
Those band clamps are not intended to seal a cut section of pipe, and they WILL introduce an exhaust leak if used in the manner described because the band does not make a complete circle around the cut. They are intended to seal a "slip joint" where the end of one of the sections of pipe is expanded so that it can slip over the adjoining pipe.
So what you should do is cut out a 12"-18" section of straight pipe as close as possible to the downpipe connection, and then replace it with a new 18"-24" section, where the extra 3" on each end can be expanded to slip over the remaining pieces of the exhaust. This will allow you to properly seal the exhaust using the band clamps, and also separate the rear section from the down pipe for servicing.
PostPosted: Thu Feb 06, 2014 5:14 am    Post subject: Reply with quote
Worked for me just fine, but YMMV.
PostPosted: Thu Feb 06, 2014 5:38 am    Post subject: Reply with quote
The band clamps will hold things together just fine, but will not provide a proper seal, especially if the cut sections are not exceptionally cleanly cut. Slip joint is not hard to make (plenty of tools available to make them), so why not do it correctly the first (or in this case, the second) time.
PostPosted: Thu Feb 06, 2014 5:44 am    Post subject: Reply with quote
Yeah, I'm not disagreeing with you about doing it "right" as it was obviously done wrong to begin with.
TajMan
PostPosted: Thu Feb 06, 2014 8:22 am    Post subject: Reply with quote
'done wrong' was the first guy who did it and a. didn't install a cat b. didn't install flanges for removal
I fixed things that already needed fixing, I just didn't go to the extent I could have the first time I was welding on exhaust.
I'm sorry I didn't want to dispute more with you guys until I double checked, none of the exhaust is 3" my mistake!
This is a very good and cheap 'race' exhaust for this car, and I don't believe the diameter is too large. Yes it was 'pieced together'.
Diameters are 2 3/8" for much of the pipe, 2 1/2" universal high flow cat converter, some re-used mandrel bent curves that are 2 3/4" at the largest, and an aftermarket muffler.
Works well! Especially the more you rev, sounds a bit race but its deeper now and way quieter than it was before with no cat and a bad leak pre-muffler.
Low rpm throttle response is not the best, I suppose that could be associated maybe with the larger than stock exhaust?
'87 924 S
