outside gas cap
pcelenta
PostPosted: Sat Feb 01, 2014 3:36 am    Post subject: outside gas cap Reply with quote
so does anyone know at what point in 1979 (late) that production changed from the outside vw golf/rabbit gas cap to the inside cap and door flap? was there a particular chassis number when the change begins?
Harm
PostPosted: Sat Feb 01, 2014 3:59 am    Post subject: Re: outside gas cap Reply with quote
See the Porsche PET:
The different fuel tank setups show production chassis
numbers for reference when first equipped/started.
HTH
Good luck!
pcelenta
PostPosted: Sat Feb 01, 2014 4:29 am    Post subject: Reply with quote
AHHH! I didn't think of the PET. Thanks Harm!
pcelenta
PostPosted: Sat Feb 01, 2014 4:44 am    Post subject: Reply with quote
no luck on the PET....76-79 shows the old style and the 80 forward shows new style...no chassis break down.
yes, Harm, I am still researching the prototypes
Ponz
PostPosted: Sat Feb 01, 2014 6:37 am    Post subject: Reply with quote
my euro 1979 931 has the twist off without the door.
77 1/2 track car
79 931 Euro
87 911 Targa
pcelenta
PostPosted: Sat Feb 01, 2014 7:23 am    Post subject: Reply with quote
If I remember correctly Vince, your car is a very early 79 like mine...with .short 924XXX chassis number.
My observation is that the switch to inside cap and flap was a model year change....so any car deemed a 1980 has the cap and flap. My initial theory was that the cap and flap came when the switch was made to the 93A01XXXXX chassis numbers. But it is not the case because there are mid/later 79 cars with the 93A01XXXX chassis numbers and outside VW gas cap.
why does this all matter? Just researching the CGT and GTS prototypes and trying to determine if there was any rhyme or reason when Porsche built them.
cheers,
larchie
PostPosted: Sun Feb 02, 2014 1:10 am    Post subject: Reply with quote
Porsche had three tank filler pipes (necks) on early 924s:
--Type A: Filler neck standard up to 1979 model without tank flap on inside.
--Type B: Filler neck, standard for 1980-1981 models no longer available in late 1982.
--Type C: Filler neck standard beginning with 1981 model and part for all models with outside tank flap.
Technical Bulletin 82-02 was issued stating the newer type Type C with the tank flap on outside should be used for 1979 Porsche 924 and older since the production of Type B was discontinued late in 1982. The installation is described in the 924 Repair Manual Vol IV, pg. 53-10. The tank vent line was changed as well. For more see Porsche Cars NA Technical Bulletin (1987) 80-02, 3 Sept 1982.
Harm
PostPosted: Mon Feb 03, 2014 9:16 am    Post subject: Re: outside gas cap Reply with quote
PM send.
Ponz
PostPosted: Mon Feb 03, 2014 10:47 pm    Post subject: Reply with quote
last four digits ??????????1715
77 1/2 track car
79 931 Euro
87 911 Targa
