Kenodog
Posted: Sat Feb 01, 2014 1:30 am Post subject: Big valve head on stroked motor ? |
Hey guys I am just putting together a list of stuff for a stroked motor. Going to be using the stock (but rebuilt) CIS system for now and was wondering if it's worth,or needed, a big valve kit for the head ? This is an area I really don't know much about and there seems to be varying opinions on the matter where it concerns a turbo charged car.
Any FACT based opinions are appreciated.
Thanks,
Leigh _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
Posted: Sat Feb 01, 2014 1:51 am Post subject: |
I believe the consensus was that larger valves weren't as helpful as having the ports reworked to improve flow as the larger valves were shrouded by the combustion chamber negating much of their gains.
The fix would be deshroud the valves by leveraging the larger bore provided by the over-bored engine block, but I don't know if you could fully deshroud the valves.
Looking over the data and the discussion in the head flow test thread and some of the newer discussions it strikes me that the gains in the Eurorace head are likely due to improved port work and not to the larger valves.
I'm looking forward to reading this thread as it develops, hopefully some good data and discussion results. _________________ Stefan
Posted: Sat Feb 01, 2014 7:54 am Post subject: |
| fiat22turbo wrote: | | I believe the consensus was that larger valves weren't as helpful as having the ports reworked to improve flow as the larger valves were shrouded by the combustion chamber negating much of their gains. |
I wouldn't say consensus, and the thread that discussed shrouding didn't provide any evidence of the potential impact of shrouding. So I don't think it's accurate to say that the shrouding negated the gains of the bigger valves. The theory was that the bigger valve ports would be shrouded and it might impose some limits to the gains that could be realized...which is not the same as negating them.
When we did the flow testing on the 931 head, my guy opened up the ports, but we didn't test with a big valve head. Aggressive porting yielded some pretty good results, and he was in favor of larger valves and smaller stems, which the big valve kit provides. While there is no doubt that some shrouding will occur, in my opinion it is a tradeoff worth making not only to increase flow to the maximum extent possible, but also to take advantage of the significant reduction in the weight of the valve train (especially when coupled with the Sten Parner solid lifters).
I am running a big valve head on the Club Sport, which has my 2.2L stroker (the version with Crower Rods and 8.0:1 CR / 87.5mm bore Diamond Pistons).
It is impossible to determine where the improvements come from and whether or not the shrouding is having any impact on the potential of that motor. Stroke, scraper, displacement, big valves, ported intake, solid lifters, hotter cam, bigger turbo, intercooler...I don't think anyone can say how each component is affecting the overall results, and I certainly don't have the R&D budget to isolate and test each variable independently!
What I can say is that the overall throttle response and rev response are dramatically improved throughout the RPM range when compared to a stock 931, and even the 937. Of course, I have not had the engine dynoed yet. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Sat Feb 01, 2014 8:48 am Post subject: |
The above-referenced thread, in case you haven't seen it.
http://www.924board.org/viewtopic.php?t=39442
Notably:
| gegge wrote: | | The 44x37mm EURORACE 924 head used excentric valveguides in order to move the intake away from the cylinderwall. |
Posted: Sat Feb 01, 2014 8:51 am Post subject: |
And in case you get bored with the above, here is a much longer discussion:
http://www.924board.org/viewtopic.php?t=20953 _________________ erstwhile owner of just about every 924 variant ever made |
MikeJinCO
Posted: Mon Feb 03, 2014 9:03 am Post subject: |
On the thread I started, I am looking at the 931 head from a NA aspect where shrouding can have a much greater effect than a turbocharged system. For me the shrouding effect throughout the valve cycle due to the cylinder wall clearance negates much of the advantage of the larger valve. I would think that the shrouding would be a moot point with 7 or 8 PSI of boost versus the vacuum generated during the NA cycle. Knowing nothing about the turbocharged systems I would think that being able to run a slightly higher boost would provide much more than the valve sizes and shrouding. Look at the modern diesels from Ford/Cummins/GMC, the valves are pretty small but that can run upwards of 25psi of boost. They run400HP,750 ft-lbs of torque with potential to double that. The gains from reduced valve train weight issue is something else completely.
Reading David Vizard's porting book most work is referencing valves at an angle to the cylinder where once the valve clears the head it angles into free space--ie an inclined valve SBC V8. On our motors the valves run parallel to the cylinder making the shrouding issue on NA motors much more significant in my opinion(he never mentions it).
Dan's approach of covering all the bases is probably the best for engine performance, unfortunately many of us have to pick and choose what we can do. If I could get lighter weight, smaller stem valves of the same size I'd be very interested as that would allow smaller/softer valve springs which combined with solid lifters would save horsepower required for driving the cam, but I don't know if those parts are available. Many US high performance V8's have gone from double springs to progressive wound singles with significant gains at a not extravagant cost. _________________ Mike
'67 MG Midget Dp
Kenodog
Posted: Tue Feb 04, 2014 2:14 am Post subject: |
In building my last motor,which I dyno'd at 210hp at the flywheel @12psi, I realized that it was just about out of grunt without upping the boost to a level that wouldn't see the engine last long. This time I want to stroke it and get the 88-90mm pistons so it has much more torque. Combined with 12-14psi the motor will last and also put out the torque that will leave me happy and not regretting just going half arsed in the build.
I have had a stroked N/A and the torque it had was unbeleivable compared to a stock car. Sideways off the line was no problem at all and it just felt so much more ....alive.
Right now I am just slowly buying what I need to do the build, trying to cover all of the bases to ensure that the motor will be as good as it can be but also last at least a few years without grenading. Next stop is sending the crank down to Castillo's in Cali...
1981 931, Sabine
2024 KLX300
2024 KLX140 |
gegge
Posted: Tue Feb 04, 2014 3:54 pm Post subject: |
Check chapter 4: Heads - Standard and modified in David Vizards book "how to MODIFY your MINI" and figure 14-15,8.
David suggests that chamber work is extremely important in shrouded-valve heads and illustrate this by fitting a 1.156" inlet instead of a 1.093" in a standard 850 head. Flow decrease by 10% Fitting a larger 1.467" instead of STD 1.312"into a modified 1300 head resulted in less flow at high lifts. The MINIs are bore shrouded in the same way as 924. _________________ Carl Fredrik Torkildsen
Kenodog
Posted: Wed Feb 05, 2014 1:18 pm Post subject: |
Thanks Gegge that is the kind of info I was looking for. Sadly there are not many people around here that would know enough to do a good job unshrouding the valves. Anybody have a good guy that could also flow test and show some results ?
1981 931, Sabine
2024 KLX300
2024 KLX140 |
