MikeDanger
Posted: Tue Jan 28, 2014 3:14 pm Post subject: Cold start valve button+LED |
I added a button to activate the CSV, with an LED so I could see when it was working.
VIDEO
http://youtu.be/gzz6m2E7ZRs _________________ It was either this or a giant box of legos |
MikeDanger
Posted: Tue Jan 28, 2014 3:19 pm Post subject: |
also I think Im going to also wire in the Fuel pump so that I can manualy turn it on.
Will priming the eninge help with HOT start? since I can then pressurize the system before I crank? _________________ It was either this or a giant box of legos |
Posted: Tue Jan 28, 2014 6:08 pm Post subject: |
When i had the NA i had a hot start problem.
The fuel pump relay died and i replaced it with a modified normal 12v relay so when i turned the key the pump would be on and never stop.
After i did that i didnt have a hot start problem anymore as i would just let it fill up the system for a couple more seconds.
| MikeDanger wrote: | also I think Im going to also wire in the Fuel pump so that I can manualy turn it on.
Will priming the eninge help with HOT start? since I can then pressurize the system before I crank? |
_________________ Supercharger and EFI kits
scm924s
Posted: Tue Jan 28, 2014 7:26 pm Post subject: |
| morghen wrote: | | the pump would be on and never stop.] |
And if you are involved in an accident the pump continues to run and run....
Not a good idea IMHO! _________________ 1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold |
Ian89C4
Posted: Wed Jan 29, 2014 11:24 am Post subject: |
Take a look at the fuel pressure accumulator...I think that is our hot start issue. The cars will always have hot start issues...but I don't think this will solve the problem...only put a patch on it. _________________ Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala") |
Posted: Wed Jan 29, 2014 12:50 pm Post subject: |
Mine doesn't have a hot start issue, and it has no workarounds. _________________ 78 924 NA
5-lug |
MikeDanger
Posted: Wed Jan 29, 2014 4:06 pm Post subject: |
| !tom wrote: | | Mine doesn't have a hot start issue, and it has no workarounds. |
Lucky you.
But at least I have to option to control it. Plus I like watching the LED to know when the CSV is working. On subsequent starts the CSV did not come on.
Once its all fixed, should it fail again in the future, Ill have the back up solution ready to go rather than get stuck. _________________ It was either this or a giant box of legos |
Posted: Wed Jan 29, 2014 4:39 pm Post subject: |
Cold start buttons are for shitty mechanics. _________________ Toofah King Bad
MikeDanger
Posted: Wed Jan 29, 2014 5:00 pm Post subject: |
| Rasta Monsta wrote: | | Cold start buttons are for shitty mechanics. |
cool story bro _________________ It was either this or a giant box of legos |
maybeoneday
Joined: 09 Dec 2013 Posts: 82 Location: Melbourne, Australia
Posted: Wed Jan 29, 2014 5:24 pm Post subject: |
Thats because it never gets hot in BC. Sorry bad joke... hea. |
Brockoli
Joined: 06 Feb 2007 Posts: 621 Location: Edmonton, Alberta, Canada
Posted: Thu Jan 30, 2014 8:36 am Post subject: |
I tried the csv button thingy but unistalled it once I actually fixed the probelm which is probably your fuel accumulator.
+1 to Rastas comment.
You can prime the pump with the key in the on position and move the power mirror toggle button thingy. I have no idea why this works but it does. _________________ '80 924 M471,Wideband O2, Full coilover susp,23/19 sways,Bilstiens,KLA Strut Brace,Roll Bar,Test Pipe,BBS RS, Willwood BBK
'79 924 Sebring Edition(Sitting) |
musicalannette
Posted: Thu Jan 30, 2014 10:15 am Post subject: |
The amount of people i remeber with mk1 golfs going on and on about csv's and problems when there weremany about, its when or if it does fail it will pay dividends. _________________ I KNEW white wall tyres were invented by Americans .....just not at Boeing.... to be fitted on the 737..... |
larchie
Posted: Thu Jan 30, 2014 10:20 am Post subject: |
| If there is a hot-start problem often there is a leak in injectors, cold start valve, warm-up regulator, or fuel distributor. If not that, then Porsche recommends installing a second 20 cc accumulator and relocating the fuel pump with Installation Kit PN 477 298 111. |
Posted: Thu Jan 30, 2014 3:52 pm Post subject: |
| Brockoli wrote: | | You can prime the pump with the key in the on position and move the power mirror toggle button thingy. I have no idea why this works but it does. |
...On late model cars. _________________ 78 924 NA
5-lug |
Posted: Thu Jan 30, 2014 4:15 pm Post subject: |
| MikeDanger wrote: | | cool story bro |
I'm not your bro, guy. _________________ Toofah King Bad
