Trailer coupling installation?
McGyver
PostPosted: Tue Dec 24, 2013 10:17 am    Post subject: Trailer coupling installation? Reply with quote
Ok... so I found this:
And now is the question... where it should be mounted and where should wiring goes inside trunk?
Anyone know ... maybe there is any manual about it?
931 82' - 5000km after full engine rebuild
SOLD: 924 81' N/A- with turbo gearbox "dogleg" - great but mysterious car
www.mauser98k.internetdsl.pl - if someone like german rifles (English version avalible)
Marlando
PostPosted: Tue Dec 24, 2013 3:25 pm    Post subject: Reply with quote
Sits just below bumper. You will have to remove bumper and maybe muffler to get all mounting bolts in. Plug cable enters behind spare tyre via a rubber grommet.
'79 924.
4 speed manual.
Formerly Indiana Red, now Green.
Marlando
PostPosted: Tue Dec 24, 2013 5:48 pm    Post subject: Reply with quote
'79 924.
4 speed manual.
McGyver
PostPosted: Wed Dec 25, 2013 7:44 am    Post subject: Reply with quote
Great
Is it mounted under bumper "holders"?? - 2 bolts/side and under "back" pockets 2 addional mounting holes which should be drilled as I see
I found original manual but is really poor quality and is in German which I don't understand too much.
Marlando
PostPosted: Mon Dec 30, 2013 1:55 pm    Post subject: Reply with quote
Hopefully you have all the mounting plates.
'79 924.
4 speed manual.
PostPosted: Tue Dec 31, 2013 3:14 am    Post subject: Reply with quote
Can't you just McGuyver something?
txjake
PostPosted: Tue Jan 07, 2014 3:47 am    Post subject: Reply with quote
Just curious: what could you pull with a twofah?
1978 924, aka The Red Rocker
kcoyle
PostPosted: Tue Jan 07, 2014 7:00 am    Post subject: Reply with quote
More twofah.
McGyver
PostPosted: Sun Jan 12, 2014 1:03 am    Post subject: Reply with quote
First try...
But how they make that mounting holes on each side... there's really little space out there to use drill. I don't know I have to figure out something.
Nameplate... not brand new but all can be read
I have to remove exhaust and rear heatshield to make that holes hope it will work.
What for?... for example (i found somewhere on internet that photo):
McGyver
PostPosted: Mon Jan 13, 2014 10:49 am    Post subject: Reply with quote
I had to make new plates like that (thanks for photo)
That was only thing I didn't have but I make in my work two almost identical to original ones but from stainless steel... no rust
I can confirm it's possible to use small drill from inside lugage compartment. But lower hole I make from outside
Right now I complete with 4 mounitng bolts with bumper holders (I add new imbus screws there to make it easy to put in or out) and I make that two holes on fuel pump side
Still have to remove rear heat shield and drill last two holes... hope it will be enough space under car to do this on left side.
As I know plug cables shouldn't go through (behind) spare tire... but somewhere on left side of lugage compartment. I check that later
I replace one rivet which was missed on nameplate, now all looks great
McGyver
PostPosted: Tue Jan 14, 2014 12:17 am    Post subject: Reply with quote
After 3 hours I made polish mounting manual... That poor photo was enough hopefully. I'll made original "good quality" german manual later, maybe someone will need it too.
https://www.dropbox.com/sh/szod8rj06ymcbmu/y97rLFcHAr
I wonder is there any complete manual online... or maybe someone got one??
Marlando
PostPosted: Wed Jan 15, 2014 5:36 pm    Post subject: Reply with quote
Pics showing cable entry and removable coupling ball.
'79 924.
4 speed manual.
McGyver
PostPosted: Wed Jan 15, 2014 11:02 pm    Post subject: Reply with quote
Thanks
I wonder where that cable should really go Mine is original and I really can't trace where it should go or it was too short. Manual doesn't say anything about wiring, only that you can buy it separately.
McGyver
PostPosted: Tue Jan 21, 2014 9:02 am    Post subject: Reply with quote
I wonder how to make it look better
I can make a how to install "that thing" if someone is interested in it? I just need to find proper way to install connection wires...
