george01
Posted: Mon Oct 21, 2013 10:39 am Post subject: steering wheel/shaft ground |
where is the ground for the steering wheel shaft? my horn doesn't work. no ground on the shaft . 1981 924 na
george |
Posted: Mon Oct 21, 2013 6:26 pm Post subject: |
its through the bearings.
An earth can be rigged using some wire loosely wrapped around the shaft and connected to earth and the shaft. _________________ Porsche 924 1984 (UK import) NA
Posted: Thu Oct 31, 2013 11:42 pm Post subject: |
Also check out the horns themselves, they can rot out. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Slam
Posted: Sat Dec 21, 2013 12:03 pm Post subject: |
Is there not a ring terminal attached to a screw into the crossmember as well? _________________ '88 944 Auto - may or may not resurrect |
peter_hargraves
Posted: Wed May 11, 2016 9:23 am Post subject: steering column ground wire |
| did you ever find the ground wire on the steering column? I am looking for the same thing. Trying to figure out why the horn only works when the steering wheel is turn at a very specific angle. |
peter_hargraves
Posted: Wed May 11, 2016 12:25 pm Post subject: Horn ground wire |
The ground wire is just in front of your oil sump. Remove the undercarriage cover and you will see it. The horn grounds through the steering column through the rack and pinion.
The link below has photos of it.
http://rennlist.com/forums/924-931-944-951-968-forum/787947-ground-path-for-horn.html
I discovered with my horn that it only worked when the steering wheel is under pressure. Contact is made through the joints and unless they are forced into contact, the horn does not ground.
[/img] |
hdrider19
Joined: 03 May 2016 Posts: 193 Location: Catawissa Missouri(40 mi sw of St Louis)
Posted: Sun Sep 04, 2016 1:06 pm Post subject: |
Small ground wire in pic. It goes to crossmember. _________________ 87 924S |
