To turbo or not to turbo,..
Goto page 1, 2, 3, 4  Next
ThomasJoseph315
Guest
PostPosted: Mon Nov 25, 2013 2:57 am    Post subject: To turbo or not to turbo,.. Reply with quote
So, I am contemplating on power upgrades as I will be getting another car soon. While the car is plenty fast in it's own right, I wonder about turbo upgrades.
I read somewhere that the internals for the turbo and N/A models are the same, is this true? could I turbo charge the car with bolting on intake and exhaust housings with any additional hardware, like obviously turbo etc?
Keep in mind I have a 1980 engine, not a 76.
kcoyle
PostPosted: Mon Nov 25, 2013 5:11 am    Post subject: Reply with quote
Ewwwww. Sounds like a ton of work but it can be done.
http://www.924board.org/viewtopic.php?t=14435
924-76
PostPosted: Mon Nov 25, 2013 8:08 pm    Post subject: Reply with quote
It is possible and been done by others here, but probably much cheaper and certainly much easier to sale your NA buy a turbo.
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
PostPosted: Tue Nov 26, 2013 1:01 am    Post subject: Reply with quote
<FACEPALM>
Can you turbo and NA? Short answer is yes. Long answer is No, NA and Turbo internals are NOT the same. No, you can't just bolt on a turbo. No, you can just bolt on a turbo exhaust mani. No, you can't just bolt on a turbo intake mani.
Read this. The whole thing. Then read it again. Then if anything is unclear, come back and ask clarifying questions.
http://www.924board.org/viewtopic.php?t=25795
</FACEPALM>
PostPosted: Tue Nov 26, 2013 1:53 am    Post subject: Reply with quote
Depends on whether you want to try and use the factory turbo parts, which are lacking in some areas, but also provide a lot of well thought out engineering work. That requires a lot of work to change over and you'd be better off buying a factory turbo car and swap parts you want from the NA to the turbo (chances are you'd get 5-lug brakes, etc in the process)
If you just want to put a turbo on the NA motor, then you could track down a BAE or Windblown aftermarket turbo manfiold (a simple cast iron "log" that runs to the front of the motor with a flange for the turbo) and put a small turbo on it and figure everything out on your own. There was even a Windblown turbo converted car for sale recently, would make a good donor I think.
If you have a friend that can weld cast iron, you could build a replica using cast iron Weld-El's and some flanges waterjet/laser cut from steel, they show up on eBay from time to time.
Another option that has been done was to build a cross-over pipe off the stock exhaust manifold to mount the turbo on the driver's side, like the 944 turbo.
Lots of work either way with getting exhaust piping routed properly to clear everything and to ensure that critical components don't end up getting damaged via heat.
Biggest issues will be the fuel and ignition tuning as well as ensuring there is enough cooling for the motor. If you keep the stock CIS system, it would need to be modified to handle the addition of boost. An EFI conversion would allow more fine tuning, but isn't exactly easy to do either, depending on your skillset and comfort level.
Ron Davies makes a better radiator that drops into the 924 (or you could adapt a 944/944 turbo radiator, not much different price wise when buying new)
Bottom line, do some searching here and figure out what works best for your skillset, budget and time.
PostPosted: Tue Nov 26, 2013 3:50 am    Post subject: Reply with quote
Hey, isnt this the guy who called us names and went coocoo about his modded NA being faster than a 911 on the straights?
Well for what its worth...if you want to be faster than a 911 on the corners turbo is not the right way.
ThomasJoseph315
Guest
PostPosted: Tue Nov 26, 2013 3:57 am    Post subject: Reply with quote
Well think of it is,.. I am getting another car soon and I am thinking of all the different ways to play with this thing.
Turboing seems like to much of a hassle.
V8 LSX swap sounds fun
Electric conversion sounds like fun
so many choices.
PostPosted: Tue Nov 26, 2013 6:23 am    Post subject: Reply with quote
Start breeding hybrid super mice hank the na install a pull eyed
exercise wheel and train them mice to run it. ..You could supercharge
might be less hassle than a turbo.
PostPosted: Tue Nov 26, 2013 7:09 am    Post subject: Reply with quote
What.
The.
F$%^.
PostPosted: Tue Nov 26, 2013 7:33 am    Post subject: Reply with quote
Must be texting again.
PostPosted: Tue Nov 26, 2013 8:32 am    Post subject: Reply with quote
morghen wrote:
Hey, isnt this the guy who called us names and went coocoo.
PostPosted: Tue Nov 26, 2013 9:30 am    Post subject: Reply with quote
Which one?
924-76
PostPosted: Tue Nov 26, 2013 9:34 am    Post subject: Reply with quote
emoore924 wrote:
Which one?
1980 931S
snakoil
PostPosted: Tue Nov 26, 2013 11:07 pm    Post subject: Reply with quote
supercharging is in fact much easier as you only need a custom bracket (no need to change any exhaust component)
No need to tap oil feed in your oil pan if you take a sellf oiled unit like a Toyota SC12 used on Aw11 MR2
These superchargers can be found for cheap, I bought 2 for 200$
the electric swap is also very interresting as there are a lot of how to's and once built it is very easy and cheap to repair if it ever brakes.
Battery technology is getting more mainstream and you can buy decent range now.
If I'd ever go that route I would also try to swap most of the steel body parts for fiberglass to keep weight down as much as possible.
1979 924 NA
ThomasJoseph315
Guest
PostPosted: Thu Nov 28, 2013 7:38 am    Post subject: Reply with quote
There is no "us" I never took on the entire forum, I was talking to you. You do not speak for anyone else in this forum besides yourself, nor do you speak for the forum its self. If you're hell bent on insulting another mans car without even asking for details about it, you really have no place here on the forums. And no, I will not list my mods atm cause quite frankly I don't want to, and to be honest don't I know all of what they are as work was done to the engine before I bought the car which is why I never listed them in the first place
I hold no value of your opinion whatsoever, even if you are right, I'll find my answers from someone else. In other words, stay out of my threads your not wanted.
As far as my car being faster then a 911, it took a few weeks but I bumped into the guy at Supercar Sunday last week and it was actually a 2001 996 3.4ltr, which a lot of people mistake them for a 911's. We discuss what happened and the possibilities of why I over took him. He has an automatic, I have a 4 speed manual. He said the moment he noticed I passed him was when his car down shifted gears going around a corner near the Reseda on ramp on the 101. Since I didn't shift gears and since I don't have a sway bar, instead of slowing down and staying in my lane, I used a few lanes to widen my path and keep the peddle to the floor while he stayed in the far left lane which was the thing that did him in, he wasn't a skilled driver. When I came out of the turns going on the straight away I had more momentum, which is why I pulled away on the straightaways. He was in fact a Doctor in Ventura county looking for fun. Also, I've stated this several times, my car isn't stock, it's a 1980 engine and if I had to guess it's around 150 horsepower after all the mods I can figure into it. I assure you a skilled driver Vs. a lead foot driver, the skilled driver will win every time and that's what happened here.
That being said a skilled driver can make up a 1.5 second difference, and this is just drag racing, not where there is turns and people are already at speed.
996
My 924
My engine stamp as proof this isn't the stock engine in a '76
Now put it to rest, stay in your own threads and have a nice life.
Page 1 of 4
