steering wheel/shaft ground
george01
PostPosted: Mon Oct 21, 2013 10:39 am    Post subject: steering wheel/shaft ground Reply with quote
where is the ground for the steering wheel shaft? my horn doesn't work. no ground on the shaft . 1981 924 na
george
PostPosted: Mon Oct 21, 2013 6:26 pm    Post subject: Reply with quote
its through the bearings.
An earth can be rigged using some wire loosely wrapped around the shaft and connected to earth and the shaft.
PostPosted: Thu Oct 31, 2013 11:42 pm    Post subject: Reply with quote
Also check out the horns themselves, they can rot out.
Slam
PostPosted: Sat Dec 21, 2013 12:03 pm    Post subject: Reply with quote
Is there not a ring terminal attached to a screw into the crossmember as well?
peter_hargraves
PostPosted: Wed May 11, 2016 9:23 am    Post subject: steering column ground wire Reply with quote
did you ever find the ground wire on the steering column? I am looking for the same thing. Trying to figure out why the horn only works when the steering wheel is turn at a very specific angle.
peter_hargraves
PostPosted: Wed May 11, 2016 12:25 pm    Post subject: Horn ground wire Reply with quote
The ground wire is just in front of your oil sump. Remove the undercarriage cover and you will see it. The horn grounds through the steering column through the rack and pinion.
The link below has photos of it.
http://rennlist.com/forums/924-931-944-951-968-forum/787947-ground-path-for-horn.html
I discovered with my horn that it only worked when the steering wheel is under pressure. Contact is made through the joints and unless they are forced into contact, the horn does not ground.
[/img]
hdrider19
PostPosted: Sun Sep 04, 2016 1:06 pm    Post subject: Reply with quote
Small ground wire in pic. It goes to crossmember.
87 924S
