brake drag?
B
PostPosted: Tue Sep 24, 2013 5:50 am    Post subject: brake drag? Reply with quote
Hey everyone
on my last drive out I noticed a strong pull to the left (drivers side - US) and on a hunch - I checked the brakes to see if something was binding - when I jacked the car, I tried spinning the wheels and I could hear , what sounded like the brake dragging. The wheel moved, but not as freely as I thought it should. When I checked the passenger side it was worse, the wheel hardly rotated.
Is this something that could have caused such a pull while driving?
And does anyone know what could cause the brakes to start to do this?
Any thoughts?
Sean
1979 924 n/a
BAE turbo
5-speed snailshell
PostPosted: Tue Sep 24, 2013 7:32 am    Post subject: Reply with quote
rubber flex hoses failed internally
calipers or shoes physically sticking.
Pull the problematic wheel and see if cracking the bleeder valve and prying on the caliper to move the pads will fix the issue. If so then your flex lines need to be replaced.
If not then you've got a caliper sticking and will need to be rebuilt/lubricated properly.
B
PostPosted: Tue Sep 24, 2013 7:38 am    Post subject: Reply with quote
Thanks Stefan
I replaced the rubber with the braided hoses - I think a year or 2 ago - does not mean it could not fail - I had hoped at the time that it would be better. I will try the other things you mentioned
do you think it could create that kind of pull? I thought I read somewhere that that could be a problem.
1979 924 n/a
BAE turbo
5-speed snailshell
PostPosted: Tue Sep 24, 2013 7:44 am    Post subject: Reply with quote
Certainly can and will. If one brake is on and the other ones are off, it will pull the car in that direction. Its how modern stability control systems work.
Slam
PostPosted: Thu Sep 26, 2013 12:55 am    Post subject: Reply with quote
What Stefan said. Also, if it was my car I'd rebuild those calipers right away. In fact, I would have done that at the same time I changed the brake hoses. How are your bearings?
'84 944 - kid blew motor
'83 944 - resting comfortably. For 12 years
'87 944 - sideswiped by trucker
'80 924 - gone
'78 924 - gone
'77 924 - rusting comfortably
B
PostPosted: Fri Sep 27, 2013 2:06 am    Post subject: Reply with quote
yes - I replaced everything a year or 2 ago - but admittingly, I am not 100% sure about them - I do not have any vibration so I thought the bearings may be ok (also new) the car did not behave this way when the brakes were first done, but I am sure that does not mean something could not show up later. I am hoping to get a look today if not it will have to wait until Sat. I will look to see how everything is working. Is there anything else I should look at while I am under there?
thanks again
Sean
1979 924 n/a
BAE turbo
5-speed snailshell
PostPosted: Fri Sep 27, 2013 7:17 am    Post subject: Reply with quote
Not looking good for solid disc calipers or rebuild kits. Might be time for 4 wheel disc conversion?
PostPosted: Sat Sep 28, 2013 12:12 am    Post subject: Reply with quote
or upgrade to the slightly larger Passat calipers, which might be more commonly available in decent rebuilds.
B
PostPosted: Sat Sep 28, 2013 1:06 am    Post subject: Reply with quote
What is this new option, Passat ? is this something that you have tried?
1979 924 n/a
BAE turbo
5-speed snailshell
PostPosted: Sat Sep 28, 2013 1:44 am    Post subject: Reply with quote
There's references to the Passat/Audi caliper upgrade on the forum. Google is thy friend.
Ultimately, if you can find a donor and the proper wheels a 5-lug conversion isn't difficult to pull off either.
http://www.924board.org/viewtopic.php?t=18769
http://www.924board.org/viewtopic.php?p=188836
Slam
PostPosted: Sat Sep 28, 2013 1:53 am    Post subject: Reply with quote
Is the 79 brake routing from the MC a TT, H or X split? Maybe the MC is failing.
'80 924 - gone
'78 924 - gone
B
PostPosted: Sat Sep 28, 2013 7:23 am    Post subject: Reply with quote
thanks everyone
I believe the '79 has an "x" connection - front rt. with rear left and visa versa
I did find some older posts on here that used a passat set-up I will check the other links as well
I did a quick test last night, and the fluid had no problem flowing and had no bubbles. When I spun the wheels, I had my son hit the brakes and they stopped quickly. I also did not see any strange dragging type marks on the rotors - they looked clean - like I would imagine newer brakes would look.
I am concerned about pedal travel and the mc - I am going to check the adjustment on the rear - they may need attended to.
I thought I had a line on a 944 for some parts earlier when the car had transmission issues. But it was sold before I could look into it.
Cash will be a little tight for a while so I can't look into too much - besides trying to get this to work at the moment.
1979 924 n/a
BAE turbo
5-speed snailshell
B
PostPosted: Mon Sep 30, 2013 12:48 am    Post subject: Reply with quote
I did a quick test drive after bleeding, adjusting and tugging on some of the suspension. I did not hear anything while it was on the stands.
I noticed a thump thump sound when coming to a stop - it's a low sound but on freshly paved road it is consistent and noticeable.
could that still be brake or would that be suspension?
the only thing was I could not tell what side - if that matters at this point
any thoughts?
thanks
Sean
1979 924 n/a
BAE turbo
5-speed snailshell
PostPosted: Mon Sep 30, 2013 7:39 am    Post subject: Reply with quote
Could easily be a wheel bearing.
78 924 NA
5-lug
B
PostPosted: Tue Oct 01, 2013 6:28 am    Post subject: Reply with quote
thanks - I was kinda leaning that way
1979 924 n/a
BAE turbo
5-speed snailshell
