Kenodog
Posted: Thu Sep 05, 2013 12:00 am Post subject: |
Yup, though I got mine from CIP1.com (or .ca for you canuckistani's) _________________ Stefan
Kenodog
Posted: Thu Sep 05, 2013 5:01 am Post subject: |
Awsome! Thanks Fiat22turbo. _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
Posted: Thu Sep 05, 2013 5:17 am Post subject: |
| fiat22turbo wrote: | | Yup, though I got mine from CIP1.com (or .ca for you canuckistani's) |
+1
Got 28mm bars, have punished them for a couple years on track, works fine.! _________________ 1980 924 Turbo
nickthompson
Posted: Thu Sep 05, 2013 8:38 am Post subject: |
| So I guess that means our bars are 26 9/16 inches long. Thats good to know. |
Posted: Fri Sep 06, 2013 7:05 am Post subject: |
Shaggy has the 27mm bars from cip1, matched with 350# up front. QUITE stiff, but the grip. . .lordy! _________________ Toofah King Bad
Kenodog
Posted: Fri Sep 06, 2013 10:40 am Post subject: |
Oh really ? I wonder if the 28mm/#250 combo might be a bit off then ...? According to the website the 28mm bars have a # rating of 258 which should be almost a perfect match to the fronts. Maybe I should get the 27mm bars and go for a bit of understeer instead. God I hate having to make these decisions..  _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
Posted: Fri Sep 06, 2013 11:41 am Post subject: |
Depends on the corner weights.
My 924 with its lightweight front end and 325# springs with 28mm rear bars, understeers a bit.
However a 931 with a steel front end might not be too bad with something like that. _________________ Stefan
Power Tryp
Joined: 16 Apr 2009 Posts: 435 Location: Calgary, Alberta
Posted: Sat Sep 07, 2013 3:05 am Post subject: |
| nickthompson wrote: | | So I guess that means our bars are 26 9/16 inches long. Thats good to know. |
Yup, as stated in the tech section any VW bar with a 26 9/16" length are a match for our cars. http://www.924.org/techsection/technical.htm _________________ Melanie - 1980 931
NoName - 1980 931 (seeking rebuild)
Green tartan interior, you don't see that on a Civic. |
Posted: Sat Sep 07, 2013 3:17 am Post subject: |
My 28s are matched to 350 springs, + stiffer sway bars (adjustable 28mm/ 22mm). Its very well balanced at the moment.
25 bars matches 250 pretty good on a standard car.. _________________ 1980 924 Turbo
Posted: Sun Sep 08, 2013 12:49 am Post subject: |
With 205 up front and 225 in the rear, and 23/19 sways, Shaggy is 100% neutral.
Fwiw, slight oversteer setup on the race car is 450#/30mm, 26/20 sways. _________________ Toofah King Bad
Kenodog
Posted: Sun Sep 08, 2013 1:40 am Post subject: |
Well the car came with 170# in the front and 25mm in the back so by upgrading to 250# inthr front there is no way the car will still be neutral. The plan for bits is 7&8 Fuchs with 205/225's, boxed control arms with poly bushings all around,21 sway up front and 18 in the back, and 250# springs with ? mm bars in the rear end. I have everything above already except the bars.
Suggestions now that you know the rest of the gear ? (Sorry, should have mentioned that before.) _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
Posted: Sun Sep 08, 2013 2:45 am Post subject: |
What are you going to use the car for? If lots of track days, the 250# springs might not be enough. Then swapping out the Torsion bars again, would not be fun. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Kenodog
Posted: Sun Sep 08, 2013 11:39 am Post subject: |
The car is just for fun. Maybe a track dwy here or there but mostly just stress relief. _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
Posted: Sun Sep 08, 2013 12:13 pm Post subject: |
If I were me, I'd skip upgrading the bars and go with the rest of the plan. Install the 250# springs up front, the sways, and see what happens. _________________ '83 944 Track car.
