Aftermarket torsion bars..
Kenodog
PostPosted: Wed Sep 04, 2013 3:11 pm    Post subject: Aftermarket torsion bars.. Reply with quote
Does anyone know if these will fit our cars ? There is lots of talk on the VW forums about using 944 bars but there's a bit of confusion as to the actual spline count/length.
http://www.pacificcustoms.com/mm5/merchant.mvc?Screen=PROD&Store_Code=PC&Product_Code=ac501302-28&Category_Code=torsion-bars-and-leaf-springs
If they do fit it's a damn good deal compared to the other "Porsche" vendors.
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
PostPosted: Thu Sep 05, 2013 12:00 am    Post subject: Reply with quote
Yup, though I got mine from CIP1.com (or .ca for you canuckistani's)
Kenodog
PostPosted: Thu Sep 05, 2013 5:01 am    Post subject: Reply with quote
Awsome! Thanks Fiat22turbo.
1981 931, Sabine
2024 KLX300
2024 KLX140
PostPosted: Thu Sep 05, 2013 5:17 am    Post subject: Reply with quote
+1
Got 28mm bars, have punished them for a couple years on track, works fine.!
nickthompson
PostPosted: Thu Sep 05, 2013 8:38 am    Post subject: Reply with quote
So I guess that means our bars are 26 9/16 inches long. Thats good to know.
PostPosted: Fri Sep 06, 2013 7:05 am    Post subject: Reply with quote
Shaggy has the 27mm bars from cip1, matched with 350# up front. QUITE stiff, but the grip. . .lordy!
Kenodog
PostPosted: Fri Sep 06, 2013 10:40 am    Post subject: Reply with quote
Oh really ? I wonder if the 28mm/#250 combo might be a bit off then ...? According to the website the 28mm bars have a # rating of 258 which should be almost a perfect match to the fronts. Maybe I should get the 27mm bars and go for a bit of understeer instead. God I hate having to make these decisions..
1981 931, Sabine
2024 KLX300
2024 KLX140
PostPosted: Fri Sep 06, 2013 11:41 am    Post subject: Reply with quote
Depends on the corner weights.
My 924 with its lightweight front end and 325# springs with 28mm rear bars, understeers a bit.
However a 931 with a steel front end might not be too bad with something like that.
Power Tryp
PostPosted: Sat Sep 07, 2013 3:05 am    Post subject: Reply with quote
Yup, as stated in the tech section any VW bar with a 26 9/16" length are a match for our cars. http://www.924.org/techsection/technical.htm
Melanie - 1980 931
NoName - 1980 931 (seeking rebuild)
Green tartan interior, you don't see that on a Civic.
PostPosted: Sat Sep 07, 2013 3:17 am    Post subject: Reply with quote
My 28s are matched to 350 springs, + stiffer sway bars (adjustable 28mm/ 22mm). Its very well balanced at the moment.
25 bars matches 250 pretty good on a standard car..
PostPosted: Sun Sep 08, 2013 12:49 am    Post subject: Reply with quote
With 205 up front and 225 in the rear, and 23/19 sways, Shaggy is 100% neutral.
Fwiw, slight oversteer setup on the race car is 450#/30mm, 26/20 sways.
Kenodog
PostPosted: Sun Sep 08, 2013 1:40 am    Post subject: Reply with quote
Well the car came with 170# in the front and 25mm in the back so by upgrading to 250# inthr front there is no way the car will still be neutral. The plan for bits is 7&8 Fuchs with 205/225's, boxed control arms with poly bushings all around,21 sway up front and 18 in the back, and 250# springs with ? mm bars in the rear end. I have everything above already except the bars.
Suggestions now that you know the rest of the gear ? (Sorry, should have mentioned that before.)
1981 931, Sabine
2024 KLX300
2024 KLX140
PostPosted: Sun Sep 08, 2013 2:45 am    Post subject: Reply with quote
What are you going to use the car for? If lots of track days, the 250# springs might not be enough. Then swapping out the Torsion bars again, would not be fun.
Kenodog
PostPosted: Sun Sep 08, 2013 11:39 am    Post subject: Reply with quote
The car is just for fun. Maybe a track dwy here or there but mostly just stress relief.
1981 931, Sabine
2024 KLX300
2024 KLX140
PostPosted: Sun Sep 08, 2013 12:13 pm    Post subject: Reply with quote
If I were me, I'd skip upgrading the bars and go with the rest of the plan. Install the 250# springs up front, the sways, and see what happens.
