Dutch924-racer
Joined: 23 Jul 2007 Posts: 1081 Location: The Netherlands
Posted: Tue Aug 20, 2013 5:09 am Post subject: 924 GTS breather system |
Does anybody have more detailed info on the GTS breather system?
The GTS has an extra breather pipe on the rear of the valve cover that goes to the catch tank (first picture).
But I would like to know where the breather pipe on the engine goes to on a GTS (second picture)
 _________________ 937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
Forge recirculation valve + boost controller |
Posted: Tue Aug 20, 2013 8:41 am Post subject: |
Looks like a common crankcase breather port on any 931 block. In a 931, a hose attaches to that nipple and runs to the top of the plastic AOS box in the first picture. Not sure on a GTS if it's the same. Send one over, we'll take a look! _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Dutch924-racer
Posted: Tue Aug 20, 2013 3:36 pm Post subject: |
The top inlet pipe of the breather is already used by the hose from the valve cover as you can see on the first picture.
So where should the hose connected to the pipe on the block (second picture) go ? _________________ 937 trackday car
Series 2 engine
Fast road camshaft
Zuffen
Joined: 31 Jul 2001 Posts: 1427 Location: Owasso, Oklahoma 74055
Posted: Tue Sep 03, 2013 11:59 am Post subject: |
there should be a drain line from the purolator seperator that goes back to the crankcase vent _________________ Bob Dodd - 924turbo@cox.net
931 1982, 944 1982 euro, 924S 1988SE, 93 968 tip 06 Silver Cayenne S, 06 Black Cayenne S
I have Way too many cars, parts for the 931,944 and 951 |
Zuffen
Posted: Tue Sep 03, 2013 12:17 pm Post subject: |
Dutch924-racer
Posted: Wed Sep 04, 2013 6:20 am Post subject: |
Will a 931 benifit of an extra breather on the valve cover?
My 931 already has the head moification on the breather that goes to the turbo like an above picture. _________________ 937 trackday car
Series 2 engine
Fast road camshaft
Zuffen
Posted: Wed Sep 04, 2013 8:03 am Post subject: |
There was a revision for the turbo breather system. You might look at your PET so you can see the two versions. I don't suspect there would be any need for any extra ventilation. _________________ Bob Dodd - 924turbo@cox.net
Dutch924-racer
Posted: Thu Sep 05, 2013 2:55 am Post subject: |
I have the revision for the turbo breather.
If there is no need for an extra breather, why did the GTS have one ?
I am using the 931 for track use. Bearing in mind the GTS is also built for track. _________________ 937 trackday car
Series 2 engine
Fast road camshaft
Posted: Thu Sep 05, 2013 3:20 am Post subject: |
Because the GTS is running more boost than a factory turbo car and the factory likely found it necessary.
Much like the Le Mans cars with the coolant system system rerouted, external water pump, etc. some changes aren't needed for a street car taken to the track occasionally, but for one built for extreme track duty, solutions to problems that occur are found and implemented.
More vents won't hurt and in fact running a vacuum on the back side of the rings will help them seal better. Turbocharged cars tend to pressurize the crankcase if the crankcase vent is configured improperly or the PCV valve fails. _________________ Stefan
Dutch924-racer
Posted: Thu Sep 05, 2013 5:36 am Post subject: |
PVC valve, does the 931 have that and what is it ?
I have a 924 valve cover with a vent that I can use.
I just wanted to know if it could not do any wrong. I was not sure if it would conflict with the revision for the turbo breather on the cilinder head (see picture below).
Series 2 engine
Fast road camshaft
Zuffen
Posted: Thu Sep 05, 2013 8:19 am Post subject: |
I dont recall any PVC system other than the Purolator catch can. The pics you reference I suspect is the GTS CS, I different beast than the GTS. In my Factory GTS Manual I don't show the rear line in question.
I dont know if opening up the case to more intake suction will make a difference in a negative way. _________________ Bob Dodd - 924turbo@cox.net
