Rewiring Help Needed
dual turbos
PostPosted: Sat Aug 31, 2013 8:40 am    Post subject: Rewiring Help Needed Reply with quote
Finishing my rewiring and got stumped at the center console, I need to know which wires go to the ac/heat slide controller, there are two male connector on the board, if I would guess it one would be the black and red wire. I have a wiring diagram from my Haynes manual but I can't seem to figure out this switch location on the wiring diagram. Also I have what I believe to be the hidden headlight switch (at least it looks like a light with 3 lines in front of it)
Which wires go to this. Hope someone can help I'm stumped.
1981 931
Lesson learned 1: when labelling your wiring make sure you have a marker that doesn't smear.
Lesson learned 2: When you take a bunch of pictures, make sure there are on your hard drive before you delete them from the memory card
(this was a painful lesson).
On the bright side nearly finished repairing all the burnt wires, and maybe I can actually drive this car finally.
Dual Turbos
