Starting problem?
doiron_dancer75
PostPosted: Wed Aug 28, 2013 6:35 am    Post subject: Starting problem? Reply with quote
My father has been working on my car this summer. We put in a new to us relay board and fixed some of the wiring that had burnt 4 years ago. Now when I start the car it dies right away. Any suggestions?
Thanks
'79 Euro 924
PostPosted: Wed Aug 28, 2013 6:52 am    Post subject: Reply with quote
Try it again and see if it stays running if you hold the key in the start position.
If it does, your ignition switch is broken. Its a cheap and relatively easy piece to replace.
check out the information at the http://www.924.org and there's some good (if not a bit dated) information there to help you out.
doiron_dancer75
PostPosted: Wed Aug 28, 2013 11:40 pm    Post subject: Reply with quote
No it doesn't stay running if I hold the key in the start position. We already changed the switch last year.
'79 Euro 924
PostPosted: Thu Aug 29, 2013 8:31 am    Post subject: Reply with quote
back to basics,
fuel- does the pump run, fuel flow, air/fuel mix
spark, is there power at the engine control unit? coil? spark correct
compression
air induction
timing
it sounds like only the CSV is working
