Posted: Thu Aug 01, 2013 11:19 am Post subject: For the unwary |
I have been plagued with bad running ever since I replaced the head gasket in April.
I replaced most ignition bits, double checked valve and ign timing, adjusted the A/F mix using a gas tester, checked for ign leaks and basically went over all the obvious stuff. Check fuel flow etc.
Had some improvement after replacing the coil and dissy cap.
Still had a miss at idle, bad misfire under medium and hard acceleration and stalling.
While checking the TIU as part of the Haynes manual checks, for some reason I checked the earth from the TIU to the battery. High resistance. This should be zero.
Cleaned up where the TIU mounts on the body and now purrs like a kitten.
SORTED!! _________________ Porsche 924 1984 (UK import) NA
Posted: Thu Aug 01, 2013 3:21 pm Post subject: |
OK, IB. WTF is TIU? _________________ Toofah King Bad
Posted: Thu Aug 01, 2013 3:27 pm Post subject: |
Transistorized Ignition Unit. _________________ erstwhile owner of just about every 924 variant ever made |
DOCO
Joined: 04 Aug 2006 Posts: 1111 Location: Keswick Ontario Canada
Posted: Thu Aug 01, 2013 10:54 pm Post subject: |
Grounds grounds grounds so important. They are even more important now with all computerised fuel injection and computerised transmissions.This is one of the biggest issues with diagnostics in the late cars. Everyone forgets the grounds!!! _________________ Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
Posted: Fri Aug 02, 2013 7:15 am Post subject: |
By habit I check my multimeter every time I turn it on.
I had one lead on the -ve and touched what should have been a good ground. (body of TIU). When I got nothing I had a WTF followed by an AHA! moment. _________________ Porsche 924 1984 (UK import) NA
Posted: Thu Aug 15, 2013 8:16 pm Post subject: |
Didn't last long.
Bad running returned.
Think I found the culprit this time. The new rotor button has zero resistance.
the book of lies says it should be about 5k so tested the old one and refitted it. at 4.8k it seemed good enough.
runs a lot better so now looking for another new rotor.
will test run again tomorrow. _________________ Porsche 924 1984 (UK import) NA
Posted: Fri Aug 16, 2013 12:25 am Post subject: |
No pics _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Posted: Sat Aug 17, 2013 7:55 am Post subject: |
Two days now, no misfires, runs and pulls well.
do you want pics of a rotor? _________________ Porsche 924 1984 (UK import) NA
sbarc
Joined: 01 Feb 2010 Posts: 545 Location: West Coast of Canada
Posted: Sun Aug 18, 2013 5:22 am Post subject: |
I would love to see a photo showing the location of the "Transistorized Ignition Unit"....so I can check my own car.
Anyone have any idea where this unit is? _________________ 1981 931 (Canadian car)
1981 931 (US car)
1990 928GT (ROW car)
1991 Toyota MR2
1989 Toyota MR2 Super Charged
1985 Toyota Supra
1973 Triumph GT6
1971 Opel GT |
Posted: Sun Aug 18, 2013 7:37 am Post subject: |
Behind the driver's headlight on the front of the inner fender. Small silver box about the size of a pack of cigarettes. _________________ Stefan
Posted: Sun Aug 18, 2013 10:58 am Post subject: |
Yep check those grounds, this is a 924S main engine ground point:
 _________________ White 87 924S "Ghost"
