smoke out of the breather/ catch tank + picture
Dutch924-racer
PostPosted: Sun Jun 09, 2013 4:10 am    Post subject: smoke out of the breather/ catch tank + picture Reply with quote
I converted my 931 to a open cone K&N air filter.
So I have placed a small breather filter on the catch tank.
But is the engine runs it smokes constantly out of the small filter of the catch tank, is this normal ?
937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
PostPosted: Sun Jun 09, 2013 5:21 am    Post subject: Reply with quote
If you remove the breather filter, does it still smoke?
Dutch924-racer
PostPosted: Sun Jun 09, 2013 6:10 am    Post subject: Reply with quote
yes
937 trackday car
Series 2 engine
Fast road camshaft
PostPosted: Sun Jun 09, 2013 6:51 am    Post subject: Reply with quote
The OEM air filter setup pulls that from the crankcase to a certain extent, and recycles it. Did the car run differently once you put the cone filter on it? You have a classic case of blow-by. I had this in spades on my previous engine, putting anything over that plastic AOS thingy produced clouds of blue smoke out the back. My current engine is totally rebuilt top to bottom, and I still get some oily moisture out of that tube; mine going to atmosphere at the moment.
I have a secondary catch-can, which didn't work with my weak motor, I plan to install it soon.
jazz guy
PostPosted: Tue Jun 11, 2013 12:29 am    Post subject: Reply with quote
I would think the the amount of smoke coming out should be minimal. I'm in the process of replacing the hoses and broken catch can as we speak. I've run my engine up to operating temp a couple times with the catch can removed and haven't noticed any smoke coming out the open hose.
Mark d
PostPosted: Sat Jun 15, 2013 5:41 pm    Post subject: Reply with quote
I get some smoke too!
Its not unusual, you just dont see it when its being recycled through the panl filter!
The more smoke, the more worn is your motor!
1980 924 Turbo S1 - Monaco Blue
PostPosted: Sun Jun 16, 2013 2:37 am    Post subject: Reply with quote
It is normal for a 931 with broken rings.
Dutch924-racer
PostPosted: Sun Jun 16, 2013 5:22 pm    Post subject: Reply with quote
Great
I will check compression first.
937 trackday car
Series 2 engine
Fast road camshaft
PostPosted: Mon Jun 17, 2013 3:39 pm    Post subject: Reply with quote
I would definetly add a small catch tank, they can be bought at every tuning store out there. But its a good idea to do leakdown and/or compression check.
Have the engine been run to operating temperature recently?, if you havent there could be moisture and petrol down in the oil (i fyou done test starts)
Dutch924-racer
PostPosted: Wed Jun 19, 2013 6:15 am    Post subject: Reply with quote
Where is a good place to put an extra catchtank ?
I also have a valve cover with an extra breather outlet like the GTS, should this help ?
937 trackday car
Series 2 engine
Fast road camshaft
PostPosted: Wed Jun 19, 2013 7:04 am    Post subject: Reply with quote
There are so many oil leaking sources on these engines, I'm surprised they sold so many. Hence, and for other reasons, there are so many sitting in fields waiting for us to discover!
If you have deleted your A/C compressor, you can install your catch-can there. It's right below the stock plastic AOS system.
Herr-Kuhn
PostPosted: Sat Jul 13, 2013 3:14 am    Post subject: Reply with quote
Consider installing a Provent air-oil separator on the car to help get rid of some of that oil. You can then recycle the collected oil by allowing it to gravity drain down back into the crankcase. These units were made for Diesel engines and have a lot of flow capacity and a built in pop off valve in the event your crankcase pressure goes too high.
I use these on the turbocharged 928s with great results. The 928s lift a lot of oil on boost, so it is a must there.
PostPosted: Sat Jul 13, 2013 4:40 am    Post subject: Reply with quote
+1
Dutch924-racer
PostPosted: Wed Sep 04, 2013 6:30 am    Post subject: Reply with quote
Checked the compression this weekend, on all the cilinders it is vey good (and exactly the same).
There is some little moisture in the oil, maybe because i haven't used the car for a long time and started it for a few short times.
The headgaket is new and i have run iit for about 800 miles since. Should I retourque it?
937 trackday car
Series 2 engine
Fast road camshaft
