Robb Northrup
Joined: 11 Oct 2006 Posts: 49 Location: Mesquite, Nevada
Posted: Fri May 03, 2013 1:42 pm Post subject: Replacement Cooling Fans for 2.0 litre |
HELP! My '80 2.0 is beginning to lose it's cooling fans. It's old...
My biggest problem is that I live in Vegas. And it's getting hot. Does anyone have a line on replacment cooling fans? Or any fan that could be substituted?
Robb _________________ I've owned too many cars. 1980 Porsche 924 with European bumpers |
Posted: Fri May 03, 2013 2:15 pm Post subject: |
original fans are ridiculously priced.
I replaced mine with a multiblade fan from the local auto shop.
(mine fitted onto the cowling but not necessary) _________________ Porsche 924 1984 (UK import) NA
Posted: Fri May 03, 2013 3:27 pm Post subject: |
Yep, measured the diameter of the stock can on my car and bought a Deraile from the FLAPS store.
I fitted mine to the stock shroud after trimming a little off the outer ring for the fan and building a slim spacer for the mount.
I've heard that one can adapt the 944 radiator and fans to the 924, which would provide some extra cooling capacity and better parts availability. I don't know what all is entailed though, but some searching here might get you the answers you're looking for.
Hope this helps! _________________ Stefan
Double post _________________ Stefan
txjake
Joined: 17 Feb 2007 Posts: 395 Location: Oklahoma City OK
Posted: Fri May 03, 2013 6:57 pm Post subject: |
Ideola has a threadnon adapting a 944 fan and Rad to a twofa
My car had a flexilite aftermatket one. Not certain how well it worked cause car wasn't running.
I lucked out at a pull a part place and got a dual fan OEM unit for my car. _________________ 1978 924, aka The Red Rocker |
kcoyle
Posted: Sat May 04, 2013 9:01 pm Post subject: |
The 944 replacement seems the best way to go to me, however I used this one from my local Autozone for the main fan. I think it was from a same year rabbit with A/C.
It's a bit taller than stock but it still fits.
Despite all the german type indications it had this sticker on it.
 _________________ 1982 931- Stock with MBC at 8psi
ksis
Posted: Sat May 04, 2013 11:01 pm Post subject: |
I work for Autopart International. The parts above are German made and the boxes are from China. I go through this once a week when parts come in from
Rock Auto or IMC.
I have a fan from a 95 jeep Cherokee on my 924 runs cool at 1/4. _________________ 77 924
64 Spitfire
76 TR6
04 Jetta
77 Schwinn Scrambler
Awsome pair of Chucks
http://www.cardomain.com/id/ksiskin |
ksis
Posted: Sat May 04, 2013 11:02 pm Post subject: |
Rock Auto or IMC.
64 Spitfire
76 TR6
04 Jetta
Kens_74_911s
Joined: 01 Mar 2011 Posts: 529 Location: Southern Pines , North Carolina USA
Posted: Sun May 05, 2013 12:58 am Post subject: fans |
PM sent - have a good set off my 82 924. _________________ Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s widebody
96 BMW 750iL
99 BMW 328i
81 VW MK1-1.8 GTI, 5 spd Pickup
02 Explorer (wife's)
92 BMW 735iL Parting
84,85,86x3,87,944. 82-924,88-924s parted
68, 70, 72, 73, 911~ 70,73 914 past Pcars |
kcoyle
Posted: Sun May 05, 2013 6:54 am Post subject: |
| ksis wrote: | | I work for Autopart International. The parts above are German made and the boxes are from China. |
Good to know. The fan seemed surprisingly well made for Mexico. _________________ 1982 931- Stock with MBC at 8psi
hbsoftware
Posted: Fri May 31, 2013 8:12 pm Post subject: 924 |
hi
i had the exact same problem with my 77 924
it had a single 4 blade fan (early rype)
it can be replaced directly (bolt on, no changes)with the 6 blade type from vw golf , vw jetta , and other vw's or Seat Ibiza, toledo or cordoba cars that use vw engines from the 70's 80's 90's they are all compatible although you must always use the 924 cowl.
be aware thet most 90's cars have dual speed fans (3 terminals) , you can hook up only the slow or the fast speed without changing the wiring. |
Posted: Fri May 31, 2013 11:31 pm Post subject: |
| txjake wrote: | | Ideola has a threadnon adapting a 944 fan and Rad to a twofa | Here's the writeup on that mod: http://www.924board.org/viewtopic.php?t=36438
The other thing you should consider is getting the cooler range thermostat and fan switch combo, which will cause the fan to switch on earlier. See my cooling system kits here: http://garage.ideola.com/prod-CoolingSystemKits.html
I have done this on all of my cars despite the fact that I do not get heat in the winter as a result. I drive so infrequently in weather where heat is essential that it's worth the tradeoff. What I find with the stock heat range is that by the time the fan kicks in, it can be really hard for the car to overcome heat soak when the ambient temp is above 85 degrees or so...especially on a turbo. So I like having the fan come on earlier to avoid getting that point entirely.
Also, be aware that if your car doesn't have AC, the second fan will never kick in with stock wiring. On the Club Sport, I have wired in a separate switch and relay so I can manually control the second fan when extra cooling is desired. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Sat Jun 01, 2013 1:47 am Post subject: |
| ideola wrote: | | Also, be aware that if your car doesn't have AC, the second fan will never kick in with stock wiring. |
Not sure I follow. . .temp switch should activate both with ignition on.
Here's my custom setup:
Not cheap, but fans are very efficient and quiet, and the assembly is much lighter than stock. _________________ Toofah King Bad
Posted: Sat Jun 01, 2013 2:56 am Post subject: |
| Rasta Monsta wrote: | | Not sure I follow. . .temp switch should activate both with ignition on. |
I don't think that is the case. On my cars with stock wiring, the fan on the LHS doesn't come on until the temp switch is triggered (after the T-stat opens up), but the second fan only comes on when the A/C switched is in the 1, 2, or 3 position. Cars without A/C don't even have the second fan. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Sat Jun 01, 2013 4:32 am Post subject: |
Weird, mine both turn on via the temp switch with ignition on. . .factory harness. You might swap in a new fan relay and/or "AC Relay" and see if the behavior changes.
See Clark's for description of "early" system. _________________ Toofah King Bad
