Posted: Thu May 16, 2013 10:20 pm Post subject: |
I suspect it's just an issue with the shift linkage. It's probably a combination of the bushings in the coupler and a worn ball-cup socket (which is on the end of the guide tube and snaps onto a ball socket that is affixed to the end of the torque tube). The plastic bushing in the cup is probably disintegrated (or nearly so), and this will add to add'l slop in the movement of the main shift bar; the guide tube needs to be relatively stationary in front-to-back orientation because it provides the pivot point for the shift linkage. Sometimes, the plastic bushing in the cup will disintegrate completely and the guide tube can come completely off of the ball. Then you won't be able to shift at all.
There is also a bushing at the front of the guide tube that bolts onto the underside of the tunnel; the "nose" of the guide tube rests in this bushing and is what allows the shift linkage to "rotate" left to right as you select gears. You can see this bushing if you remove the shifter boot and pull back the insulation. These are much less prone to wear than the other bushings, but still, it's 30 year old rubber, and I have seen some that have been completely shot, which just adds more slop to the entire linkage. _________________ erstwhile owner of just about every 924 variant ever made |
