ditch68
Posted: Thu May 16, 2013 5:05 am Post subject: Cost (or value) of a Carerra GT clone? |
Just wondering what your thoughts collectively on the value (versus build cost, which can be quite different) of a decent CGT clone.
Say I were to decide I would prefer one over my 951, what sort of price differential would I be facing?
I have been kicking the idea around, now that I have a 924 and find I really like it, and could see myselfhaving my track/weekend/fun car just as easily be a CGT clone as the 944 turbo.
Maintenance cost comparisons, build quality, G31 issues, I would want to consider everything.
Now, I do understand a clone could be anything from a 924s with fiberglass panels, all the way up to a 931 built to a high degree of historical accuracy even incorporating real 937 parts.
Id lean closer to the latter, but cost would be the deciding factor. I figure my 951 has about $10k in it, but I only ever expect it will fetch $8k realistically.
Just dreaming, but why not dream.
Or maybe I should just be rational and drive the 951 for fun. And fun it is.
Jeff _________________ Current:
1979 924, all stock.
1988 951 all track modded out and angry.
Past: 1986 951, 1988 924S, 1965 912 with '69 911T engine. |
flosho
Posted: Thu May 16, 2013 5:52 am Post subject: |
A CGT clone is probably worth 5-8k depending on the quality. If it has factory TMIC it would be on the higher side, if it's just n/a then significantly less.
Probably in most cases, building a CGT clone you will be into it for more than its really worth. _________________ [This Space For Rent] |
Posted: Thu May 16, 2013 6:50 am Post subject: |
| flosho wrote: | A CGT clone is probably worth 5-8k depending on the quality. If it has factory TMIC it would be on the higher side, if it's just n/a then significantly less.
Probably in most cases, building a CGT clone you will be into it for more than its really worth. |
No dissing but where did you pull that value out of?
I agree that a clone would be worth way less that you would put into(so would the real thing)....but if you use 937 parts the value will shoot up and stay up.
On that matter...937 parts are rare and expensive.
If you just strap some FG panels to a 924 it would be worth just the hacked 924(nothing?) and the panels.
The more money you put into it the more value it will have and the more OEM 937 parts you use the longer it will hold its value.
Value in US is totally different than in europe and even within europe the values fluctuate....so last time i looked for CGT clones, i could find cars priced 7000eur to 13000eur, depending on quality and originality.
On that subject, if it were to sell my car i would not sell it under 15k eur.
You guys in the US should start to value these cars over the crappy pllastcy new rust buckets. _________________ Supercharger and EFI kits
v8carreragts
Posted: Thu May 16, 2013 7:58 am Post subject: |
Building a clone is fun but if you go into it thinking it is going to be valued based on what you put into it you will be disappointed.
You will spend far more than you will ever get building it. This goes for just about any car. Even if you were going to restore a muscle car.
Just for instance, a few years ago I found a vendor that had had NOS GT; GTS and GTR ring and pinions. He wanted 3500 euros each. That is just for a gearset. I paid $175 for my GT front bumper rubbers a few years ago.
With the prices of the real parts you would be cheaper buying a read GT.
But as far as I am concerned the fun is in building it myself. I haven't built anything with the idea of breaking even or making money on it. Of course there can always be an exception but I wouldn't count on it. _________________ 84 944--924 Carrera GTS clone w/520HP Chevy 302 V8--RUNNING!
2015 AUDI Q7
2013 Dodge Charger R/T AWD HEMI
2013 Chevy Cruze |
ditch68
Posted: Thu May 16, 2013 9:05 am Post subject: |
I see. Well, I already fully understand the "you'll never get out what you put in it" problem, believe me.
I'm probably better off with the 951 for a lot of reasons.
937 "sexy" in itself likely cant trump all that unless it was real, but then money would be no object and I wouldn't have asked the questions.
Maybe someday I will just get lucky and be in position to have both - or a real one.
ditch68
Posted: Thu May 16, 2013 9:11 am Post subject: |
| morghen wrote: |
You guys in the US should start to value these cars over the crappy pllastcy new rust buckets. |
I already do, morghen. These have become my favorite cars, moreso the better I get to know them. I find I don't like any new cars these days. I'm perfectly happy with mu water cooled Porsches.
flosho
Posted: Thu May 16, 2013 9:59 am Post subject: |
| morghen wrote: | | flosho wrote: | A CGT clone is probably worth 5-8k depending on the quality. If it has factory TMIC it would be on the higher side, if it's just n/a then significantly less.
What CGT factory parts are on the market? Like 7 TMIC total... So unless you have one of those, the extent of a CGT clone is a $1500 body kit on a $2000 porsche.
There's no doubt that you could build a CGT and sell it for 15k to someone that falls in love with it. But realistically in the US a nicely done up CGT clone with a 931 engine and even a TMIC is gonna run $8k maybe 10k...
If a person were to go era correct seats, new interior / dash / door cards, rear seat delete, roll cage, etc.. well then you are just raising the value based on being able to part it out in the end.
If someone has actual data that says a CGT clone is worth more than 10k on average, I'd like to see it. Unfortunately, most of them are partially complete and/or not well done. _________________ [This Space For Rent] |
ditch68
Posted: Thu May 16, 2013 10:22 am Post subject: |
I would only want one that is close to real as possible. Like car show worthy with a disclaimer.
My 951 as it is now will likely outperform a stock CGT, so that would never be the goal. They are just raw, cool, unrefined, and a great piece of Porsche history. I guess unrefined is the wrong word. They are refined for the track and homologation, not the street. Thats the best part!
THAT is why I would consider swapping one for one. Either car will outdrive my track skill.
Good points, all. Older and cruder almost always piques my interest more.
v8carreragts
Posted: Thu May 16, 2013 10:50 am Post subject: |
| Quote: |
Jeff |
I agree with you as well. I don't like newer cars in general including newer Porsches. I think they have lost their originality. Many people don't even notice the newer cars as anything but just another car.
I loved the GT and GTS when they came out but couldn't afford one much less the insurance. I am fine with a clone and actually i'm better with a clone. As rare as a real one is I would be afraid to drive it for fear it would get hit. That's why I am building a clone. Besides, mine will be kind of an overpowered sleeper and only rare in the sense that it will be a one of a kind home built car. But not too difficult to replace. _________________ 84 944--924 Carrera GTS clone w/520HP Chevy 302 V8--RUNNING!
2015 AUDI Q7
2013 Chevy Cruze |
ditch68
Posted: Thu May 16, 2013 10:59 am Post subject: |
I think your car (v8 carreragt) will be a reliable, fast homage to the original. I normally do NOT like out pf maker engine swaps, but this one makes sense and is just making a great fun car on the money.
Keep us posted, you arent done quite yet, correct?
v8carreragts
Posted: Thu May 16, 2013 2:26 pm Post subject: |
No, it's not done yet. I finished the motor; torque tube; transaxle; suspension; fuel system; wiring and gauges. Basically all I have left is the dashboard which I will probably finish in about a week and prepping the body; painting it and final assembly. _________________ 84 944--924 Carrera GTS clone w/520HP Chevy 302 V8--RUNNING!
2015 AUDI Q7
2013 Chevy Cruze |
Posted: Thu May 16, 2013 6:40 pm Post subject: |
| v8carreragts wrote: | | I am fine with a clone and actually i'm better with a clone. As rare as a real one is I would be afraid to drive it for fear it would get hit. |
i agree
A clone is as cool as the original if done right, but if disaster strikes...you just build another one. If your base is a 931 then you are alot closer to the CGT.
Available(but expensive) GT/GTS parts include intercoolers, intakes, turbos, brakes, DITCs, interiors, headlights,body panels, gearboxes...i think thats enough.
I've got the M030 brakes(i've seen those on GTS cars) the DITC and the GTS turbo(K27), i've also got coilovers but those are not OEM parts...i've got FG GTS rear arches and a FG 951 front end if i would not own this car..i'd take a bank loan to buy it
They are worth what people would pay for them.. _________________ Supercharger and EFI kits
Posted: Thu May 16, 2013 10:11 pm Post subject: |
As a recent point of reference, "931GT" just sold his CGT clone. Don't know what the final price was, but he was asking $6500, and his was probably one of the better-executed conversions I've seen.
It was based on an 81 931, including the TMIC. However, the front clip on his was not exactly correct (close but some details are different), and his had fixed headlight conversion (a GTS feature) but none of the other GTS mods.
http://bringatrailer.com/2013/04/30/carrera-gt-clone-1981-porsche-924-turbo/
To achieve a "show worthy" conversion, the body and paint work alone is going to cost in the multiple thousands of dollars, depending of course on how much you can do yourself. From a paint perspective, it's much cheaper and much less work to stick with the original color of the donor chassis, but a good professional paint job will still cost as much if not more than all of the mechanical work...especially if it's red (THE most expensive color of paint to buy here in the states).
To add to the cost, if you start with a 931, you'll need to source a replacement hood (no NACA duct on the GT variants); if you start with anything else, you'll need a replacement badge panel with plastic inserts (somewhat challenging to find). The correct front valance and correct CGT rear bumper are also not easy to locate, even in fiberglass. And don't forget the welting for the hood scoop and the rear arches.
As for interior, the only place I know that has a reproduction of the pin-striped velor is http://www.werk924.com/index.php?option=com_content&task=view&id=16&Itemid=26, and it ain't cheap.
As for mechanicals, IMO, the best thing to do would be to start with a 1981 Euro 931. This will get you the Euro DITC equipped motor with 8.5:1 CR and a close-to-correct G31 trans (81 US had the Audi trans, 80 US didn't have DITC and had different gearing in the G31). There are a few details that would be hard to source or replicate like the brake ducts, the TMIC, larger bearings in the rear torsion carrier, etc. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Fri May 17, 2013 6:33 am Post subject: |
| ideola wrote: | | As for mechanicals, IMO, the best thing to do would be to start with a 1981 Euro 931. |
Or an 86 951! Toofah rear quarters and flares, 931 header panel and CGT scoop, DONE! Correct early interior, factory Fuchs, etc.
I know, I know. . .not a "correct" replica, but would be cool nonetheless! _________________ Toofah King Bad
ditch68
Posted: Fri May 17, 2013 6:44 am Post subject: |
| Rasta Monsta wrote: | | ideola wrote: | | As for mechanicals, IMO, the best thing to do would be to start with a 1981 Euro 931. |
I know, I know. . .not a "correct" replica, but would be cool nonetheless! |
I did think of that, the problems are '86 951 has the oval dash interior. Also, the turbo nose panel is different than the N/A, so you would have to fab all that. AND the readily available CGT fixed headlights are all for N/A cars, it is different again for the turbo fro t end. There is someone working on lights like this for turbos. But otherwise, you are looking at swapping all the front sheet metal and nosepiece.
About the best part is 86 was the last year (only year turbo) with the early non-ABS offset (even non ABS post 1986 944s have the different offset) so you can run Fuchs on the 86.
Beyond that, it would actually be more work than converting a 931.
