Gear changes are a bit sloppy.
RicardoRJL1
PostPosted: Tue May 07, 2013 8:29 am    Post subject: Gear changes are a bit sloppy. Reply with quote
Well, after making some adjustments in the gear linkage and shift knob, I can select all gears without any issues, except I kinda feel that it's to hard sometimes or too sloppy, what could it be?
From the gearbox they can be selected nice and smoothly.
Thanks!
It's a 4 speed manual gearbox from a 924 '77
PD: Could it be the oil level?
PD2: A pic when I bought the reman. gearbox
CorsePerVita
PostPosted: Tue May 07, 2013 8:36 am    Post subject: Reply with quote
How's the linkage at the shifter itself?
Those things are notorious for wearing themselves down and then having a ton of slop. My '77 was that way. Ended up replacing the shifter, shimming it with a very very thin washer, and putting a new end clip on it to remove the slop.
Here's a really basic visual I made some time ago for 944online, and a sort of "cheap fix" if you can't immediately fix or replace the shifter, is to shim the end.
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
RicardoRJL1
PostPosted: Tue May 07, 2013 8:41 am    Post subject: Reply with quote
To be honest, I haven't checked that...
The good part, I think I have a spare one from a 944 that was parted out.
Actually one of the issues it has is that sometimes, besides from beign hard, it's hard to engage gear, especially with reverse and first... 2,3,4 are fine...
CorsePerVita
PostPosted: Tue May 07, 2013 8:43 am    Post subject: Reply with quote
I'm uncertain if the diameter is the same. However, it'll be really obvious once you take it off and look at the insert from the shifter that the linkage fits over. It'll either look really nice and straight, or it'll be worn to a cone shape, or even a ball shape. Just be sure you don't lose the little clip off the end. They love to pop off and get lost in the foam torque tube insulation.
- 1999 Ducati 900SS
joemac
PostPosted: Tue May 07, 2013 12:30 pm    Post subject: Reply with quote
Yup, my '77 was so worn that I had to sleeve it.
Race car: my favourite palindrome.
Porsche: my favourite race car.
MikeJinCO
PostPosted: Wed May 08, 2013 11:05 pm    Post subject: Reply with quote
On mine the pin was football shaped. I drilled out the rod for nylon bushings and welded a 10mm bolt to the lever. There are several threads in the how to section.
Mike
'67 MG Midget Dp
brealytrent
PostPosted: Tue May 14, 2013 11:35 am    Post subject: Reply with quote
I looked at mine yesterday since I had it out of the car, and it is indeed a tad egg shaped. It appears this isn't the first time this has been an issue on my car however, as the pin appears to be a replacement as there are grind marks and some sloppy welding where it connects to the arm. In addition, the arm appears to have a little bit of curve to it like it got bent at one point. Never really felt that sloppy however. Still considering buying a new one though.
1977 Porsche 924 - sold
1980 Porsche 931 - sold
1984 Porsche 928 'S2' Euro - sold
2016 Ford Fiesta ST - sold
2009 Porsche Cayman
View user's profile Send private message Yahoo Messenger MSN Messenger
